Unread 05-16-2011, 01:28 PM   #1
toyage
SLC, heating cables, and lath: should be lath be under or over heating cables?
Here is a question that seems to have two answers, but I would like to hear solid reasons for each answer--rather than "that's the way it's done".
When installing electric radiant heating cables over plywood and embedding them in SLC, most SLC specifies that lath (plastic or metal) is required. The question is whether the lath goes below or above the heating cables. What are the reasons for doing it one way or the other? Is one method better (stronger, less likely to delaminate) than the other? Or is just convenience or convention?
I myself have put the lath above the heating cables, as I remember being instructed to do it that way somewhere--but now I can't remember where I learned this, so now I'm wondering.
Any thoughts would be appreciated.
Tim
toyage is offline   Reply With Quote
Unread 05-16-2011, 05:33 PM   #2
Tim, it can be installed either way. Here's a little quote from TileGuyTodd's SLC and electric heat mat thread in the Liberry:
(note #4 plastic lathe can be installed first but we have found that on some models sensors can rise in the mix, putting lathe above which requires caution in stapling, eliminates this problem with some models)
Putting the lath down first reduces potential problems with damaging the heat mat. Putting the cable down first allows the lath to keep the cable and sensor tight to the subfloor. Pick your poison.
Unread 05-16-2011, 06:04 PM   #3
The metal lath can be quite sharp, so watch the cables, regardless of which side you install it on!
Radiant Floor heating cables--what is the best brand(s) toyage Tile Forum/Advice Board 1 04-08-2010 11:44 PM
SLC over radiant heating cable: Lath or no Lath? toyage Tile Forum/Advice Board 2 04-06-2010 03:58 PM
concrete in a bathroom (heating cables) miroslav_karpis Tile Forum/Advice Board 2 01-29-2009 11:46 PM
Thinset layer over heating cables - how smooth does it need to be? Fairview Tile Forum/Advice Board 7 04-22-2008 08:11 PM
Heating cables covered by new vanity Bri Professionals' Hangout 6 04-20-2004 03:30 PM
