Unread 02-05-2011, 08:40 AM   #1
NY5600
Carrera Marble in the shower
I had carrera marble installed on the floor and walls of my shower. After one month of use the wall tiles that touched the floor tiles started to stain and draw water up into the wall tile and the floor also started to darken due to water.
I had the tile installer return and he felt I had used the wrong sealer and also at that time we removed silicone caulk he placed in the grout joint between the wall and the floor - thinking it maybe holding water in the wall.
I waited over 2 months to use the shower, I put a heater/fan in the shower
to dry it out. After two months I again sealed it with a sealer from a company that deals solely with natural stone. After two days the water mark again started to appear on the shower walls and the floor did darken a bit.
The installer feels he correctly installed the pan and the mud - the slope of the floor is very gradual and where the tile meets the wall it is flat. I have had several installers look at this - one felt it is the nature of the tile to absorb and the other believed the slope of the floor was not enough to wick the water away. Yet another believed the shelf installed near the base of the tile may be causing this problem?
What to do - everyone is afraid to take the tile off the wall claiming carrera is a beast - it just crumbles. What to do? We have a beautiful
Thanks, Marie
Marie
NY5600 is offline   Reply With Quote
Unread 02-05-2011, 10:11 AM   #2
Carrera does absorb water, but your shower sounds like there was no sloped mud bed installed under the liner and possibly the weepholes in the drain fitting are clogged.
Unread 02-05-2011, 10:13 AM   #3
Lazarus
Lazarus's Avatar
Carrera marble is not the densest of all marbles. You might get away with it on the walls, but I would have recommended something else for the floor. It will tend to wick water. Multiple coats of sealer might help...it's in and all you can do is try it. The alternative is replacement if that doesn't work.
Yes, it's possible that there is inadequate slope. 1/4" inch per linear foot is the MINIMUM. I like to see the water rush to the drain....
Unread 02-05-2011, 10:29 AM   #4
ronbo1100
Hmm. Did you see the install in progress? The flat spot indicates to me he may have left the screed boards in place or removed them then neglected to pitch that area. As long as he did none of the above then a few more coats of sealer. Three total for me is a must spaced a bit longer than suggested on bottle.
Ron
ronbo1100 is offline   Reply With Quote
Unread 02-09-2011, 01:04 AM   #5
tile911
Marie,
Carrara marble or any good quality stone is a great option for a shower installation as long as it is properly installed. It sounds to me that the backer-board could be touching the pan wicking water. Just another option to look into.
Martin
tile911 is offline   Reply With Quote
Please help problems with carrera marble lcornell Tile Forum/Advice Board 1 09-30-2007 01:50 PM
12" carrera marble flooring bridgeport07 Tile Forum/Advice Board 1 02-18-2007 10:40 PM
Carrera Marble Floor - a few questions maryland_warrior Cleaning, Restoration and Sealing 2 02-16-2007 10:41 AM
Carrera marble saddle Maack Professionals' Hangout 1 10-06-2006 06:08 AM
Grout for Carrera Marble May Tile Forum/Advice Board 3 09-22-2004 07:00 PM
