Unread 04-15-2009, 11:10 AM   #1
pooky
pooky's Avatar
Nu Heat Issue
Anyone have trouble getting a nuheat mat up to temp
220 / 72' by 30' . . .
We installed this small mat and even replaced the the thermostat
but just cant seem to get the temp up enough. Everything tests fine,
the probe is in the right spot but still can't get the floor warm enough.
Anyone have a similar experience? Thoughts?
thanks
stephen
Stephen -- Man vs. Tile -- The Battle Continues . . .
pooky is offline   Reply With Quote
Unread 04-15-2009, 11:13 AM   #2
pooky
pooky's Avatar
that should read Nu heat
thanks
Unread 04-15-2009, 11:13 AM   #3
lati_cz
michal
is it installed over concrete slab? It takes up to 8 hours to heat mat over concrete.
lati_cz is offline   Reply With Quote
Unread 04-15-2009, 11:34 AM   #4
pooky
pooky's Avatar
noooooop
over cbu--over plywood subfloor - used megalight to bed and set
fully insulated directly below floor . . .
and, the weird thing is that everything tests out ok
even when we disable the thermostat - the thing doesn't seem to get that hot
I think default max temp is 86 -- even set to that we can't seem to get this
thing hot enough??
Anyone have this experience-- what did you do?
thanks
stephen
Unread 04-15-2009, 11:52 AM   #5
dhagin
Hey Stephen,
I've had to crank the t-stat to maximum on some with deeper pours of SLU. Haven't installed nu-heat, but i believe any thicker build-up of materials, whether SLU, thinset, etc... would probably have similar results - more mass to heat.
Also, you may give the manufacturer a call to pick their brains for similar issues AND find out what their max operating temp would be.
Good luck.
dana
Unread 04-15-2009, 02:28 PM   #6
tilemanct
Tile & Stone
I had a similar problem in an old house. Joist bay ends were not insulated. Joist bays acted like wind tunnels, taking the heat with it. Insulated and problem was solved. Make sure you have a t-stat for tile and not the laminate floor one. Those are regualted to a lower temp.
CTEF Certified Installer
Unread 04-15-2009, 03:24 PM   #7
BP Tile
Send a message via AIM to BP Tile
Pooky, Just call Nu-heat and explain to them. As you know it a stone throw from your area.....
Bill
BP Tile is offline   Reply With Quote
radiant floor heat installation issue pauln Tile Forum/Advice Board 3 09-03-2008 08:22 AM
Been a while... still having same issue... NastyBurn Tile Forum/Advice Board 92 12-26-2007 09:06 PM
Large porcelain with HEAT issue thatgirl515 Tile Forum/Advice Board 5 09-18-2007 07:49 PM
Floor heat insulation between floor and heat wire? Kanukshowerguy Tile Forum/Advice Board 12 03-07-2004 09:12 PM
Heat. Can it be an issue? Bud Cline Professionals' Hangout 12 03-15-2002 07:18 AM
