Unread 09-07-2012, 10:01 PM   #14431
Marge
Marge's Avatar
Brian,
Those are govt required safety stickers advising folks on how to stand in a shower.
Marge------
Unread 09-08-2012, 04:15 AM   #14432
jondon
jondon's Avatar
Marge, nice cabin shower. Where did you get the idea for the arrows trees
Jon Donmoyer
JD Tile
CTEF Certified Installer #825
Unread 09-08-2012, 04:59 AM   #14433
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Nice drunk tank Marge! Keeping everyone upright!
Brad
Unread 09-08-2012, 10:16 AM   #14434
Tiger Mountain Tile Inc
Very nice, Marge.
Do the arrows point to where the bears are?
Unread 09-08-2012, 03:30 PM   #14435
Gary K
Vendor
Gary K's Avatar
Talking
Marge,
The bears are either in or behind the trees right... That is usually where they are unless they are just walking around... I figured black trees, black bears they probably just blended in...
Looks good by the way.
Picking them up and putting them down.
Gary
Gary K is offline   Reply With Quote
Unread 09-10-2012, 11:56 AM   #14436
Arimert
Arimert's Avatar
Layout and making cuts.
Sent from my DROID BIONIC using Tapatalk 2
Amos
ADR Tile&Stone. Certified tile installer#852
Arimert is offline   Reply With Quote
Unread 09-11-2012, 05:40 AM   #14437
jondon
jondon's Avatar
Speaking of bears this was one. Amos, what do they say? Layout, layout, layout, the rest is easy
Shower pan tearout, as suspected no preslope and drain had cement in apparently they thought it was hair and had been using draino to try and uclog it. Later 90's build so it lasted over 10 years before major failure. Builder probably out of business though he may not have known about the lack of preslope. Getter done right.
Tore it out last Wed. let it dry out good till yesterday. Trailer full of the mud bed and liner in case anyone hasn't had that joy of an experience. Yesterday, I restructured the subfloor and added bunch of sister 2X6's, new p-trap, new 3/4" plywood on top she is strong now. Still have to remove some tile at the base so I can tie the new waterproofing in. Got to rebuild bench today too and then new mud bed. Adding insulation before I put up the cement board.
Jon Donmoyer
JD Tile
Unread 09-11-2012, 07:47 AM   #14438
Floorit
Tile, Stone and Hardwood
Floorit's Avatar
Jon,
I love the way your old mudbed sparkles in the sunlight. Whenever I tear one up, it doesn't look that good.
Ray
Germantown Tennessee Tile Stone Hardwood Installation
NWFA Member
CTEF Certified Tile Installer
Tennessee Installer of Schluter Kerdi Waterproof Showers
Tennessee Installer of Laticrete Hydroban Waterproof Showers
"Life is pretty simple:you do some stuff. Most fails. Some works. You do more of what works. If it works big, others quickly copy it. Then you do something else. The trick is the doing something else." Leonardo Da Vinci
Floorit is offline   Reply With Quote
Unread 09-11-2012, 06:12 PM   #14439
jondon
jondon's Avatar
Ray, I set the flash to sparkle mode to juice things up a bit
Ready for mud, bench rebuilt the same size per the homeowner and to cover up the missing tiles. Finpan pro panels over the sides, brushed brass schluter kerdi drain.
This is the tile going on the floor, no actually that is the floor mat. I actually saw some tile like this today at the distributor and the striking resemblance to the floor mat. I could buy a bunch of these mats and do a feature wall
Jon Donmoyer
JD Tile
Unread 09-11-2012, 06:49 PM   #14440
Kilauea
LT
Kilauea's Avatar
I dig that sparkle!Thats pretty slick
*L.T.*
tandctile-dot-net
2nd generation tile installer
Kilauea is offline   Reply With Quote
Unread 09-11-2012, 07:04 PM   #14441
Peerless Tile
Tile Contractor
That's one good lookin' hoe your hanging out with....I traded my old wore out hoe for a new hoe last month.
SC Greg
Peerless Tile is offline   Reply With Quote
Unread 09-11-2012, 07:19 PM   #14442
gueuzeman
Old mud sparkles.
New drain sparkels.
Floormat sparkles.
No hoe sparkle.
Arimert- nice cuts.
Marge- nict trees.
Frankenhack Monday. Absolute black shelves with Fein tool and wet pads. Indoor. Mess free, though not quite the lucid mirror a 2500 rpm rotart tool with a full water feed gives, but it's a 3/8" edge.
gueuzeman is offline   Reply With Quote
Unread 09-11-2012, 09:27 PM   #14443
Hamilton
Bucket abuser
Hamilton's Avatar
Round peg in a square hole, or is it....round pad on a triangle? Never mind.
Jack Hamilton
Hamiltontileandstone.com
Unread 09-11-2012, 09:42 PM   #14444
Kilauea
LT
Kilauea's Avatar
Whatever works.
*L.T.*
tandctile-dot-net
Unread 09-11-2012, 10:12 PM   #14445
Gueuze, if you do that regularly you might wanna look into the sanding pad attachment for the Makita. Good bit larger than the one for the Fein. Adapting might be a problem, but you'd get support under more of your diamond pads. Think Bosch might be the same, but not certain of that.
Shower Progress Pics Electrician Al Tile Forum/Advice Board 15 07-12-2011 11:38 PM
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
