Unread 12-09-2020, 02:11 PM   #1
redlude97
Drywall to Schluter Transition sealing
This is not my wall but was watching this and was wondering how others would fix this transition to make sure its waterproof, silicone the gap?
https://youtu.be/hNtRwhuzcuc
I think the correct solution from the beginning is to use this bead but I've never seen it available before
https://www.trim-tex.com/products/ov...nel-tear-away/
Would you just grind out a channel in the mud next to the profile to allow for caulk?
Hai
redlude97 is offline   Reply With Quote
Unread 12-09-2020, 03:14 PM   #2
cbaum
I'm rather new at this but have studied Schluter stuff quite a bit.
I'm not sure why you'd want or need to waterproof a transition between kerdi and drywall. If you're getting water directly splashed onto that transition area, I think you've already done something wrong. If water is contacting the transition it is likely going to contact the drywall which is no good. I would extend the kerdi beyond the reach of direct water contact.
Charlie
cbaum is offline   Reply With Quote
Unread 12-09-2020, 03:36 PM   #3
redlude97
Like most tile installs, it extends just outside the shower alcove past the tub flange by ~1-2" which inevitably gets wet but most of the installs I've seen the tile extends out past the drywall(ie the backerboard and drywall are flush) so there is a 90 degree joint that gets caulked. In this case the tile is flush with the wall which I think looks nicer but I'm trying to figure out how to do that smoothly with the same caulked transition
Hai
Installing Schluter edging over tile backer/drywall transition marklevinson1 Tile Forum/Advice Board 2 09-13-2020 08:31 PM
CBU to drywall transition TimTaylor Tile Forum/Advice Board 6 05-15-2014 02:36 PM
CBU To Drywall Transition Question Lex Everything Tile Forum/Advice Board 14 06-25-2013 07:51 PM
CBU to drywall transition question Yaknvdub Tile Forum/Advice Board 9 10-05-2007 06:40 AM
Transition From Cbu To Drywall MChartre Tile Forum/Advice Board 6 07-04-2005 07:11 PM
