Unread 09-19-2020, 08:41 AM   #1
Daniel1018
Kerdi-Board and Cement Board
I am a DIYr working on a shower. I ran into an issue and need some advice.
I ran into a block wall. The drywall was on 5/8' strips. I can't attache the kerdi board to the strips. I saw that you can use thin set to bond Kerdi board to mansory wall. Can I attache 5/8 durack or cement boars to the wall. And then use thinset to bond the kerdi board to the cement board?
Daniel1018 is offline   Reply With Quote
Unread 09-19-2020, 11:21 AM   #2
Welcome, Dan.
I'm confused as to why you'd wanna do that.
Why would you not attach the KerdiBoard to the furring strips? Or remove the furring strips and attach the KerdiBoard directly to the block wall?
Unread 09-19-2020, 04:54 PM   #3
Daniel1018
The strips are only 5/8 and the kerdi screws are over an inch. If I but the kerdi directly to the wall. Than it will be un even with the rest of the walls.
Unread 09-19-2020, 08:00 PM   #4
Understand. Why not just find some shorter screws with which to fasten the KerdiBoard to the existing furring strips?
I think you'll not find a CBU manufacturer who will tell you to just bond your CBU to the block wall, but I suppose you could try it if you like. The cost of a failure after the shower is completed will be pretty high, though.
If you're really locked into the KerdiBoard, you could buy some thicker sections for that wall and bond it directly to the block wall.
Or you could put the drywall back on that wall and use Kerdi membrane over it in lieu of the KerdiBoard.
Any options that leave you with walls in different planes could be dealt with in a number of ways, too. Without any photos of what you're dealing with it's difficult to suggest anything else.
Green board? Cement board? Kerdi board? cburrows84 Tile Forum/Advice Board 7 03-21-2014 11:44 AM
Kerdi Board - Cement Board - Gypsum? PaulEdmonton Tile Forum/Advice Board 7 03-03-2013 07:35 AM
Cement board in tub area green board behind toilet ? Ambassador Tile Forum/Advice Board 56 09-01-2011 09:00 AM
Standard Sheetrock, Green board, or Cement Board skengum@hotmail Tile Forum/Advice Board 5 09-07-2008 06:34 PM
joint btwn cement board/green board tilingisfun Tile Forum/Advice Board 8 01-11-2006 06:38 PM
