Unread 03-09-2021, 03:33 PM   #46
BIGPHIL
BIGPHIL's Avatar
Color of caulk is personal choice, but I'd vote to match the grout color. If you do, be sure to mask off the tub the best you can to get a nice even bead. A spray bottle with denatured alcohol works wonders as you tool the silicone. Depending on the depth of the joint, backer rod would be ideal, but with such a narrow joint you'll have a tough time. Some have used window screen spline to act as a backer rod with good success on those narrow joints.
Also...that's gonna be one hell of a toilet there! Gonna need a ladder to get on that bad boy!
Phil
BIGPHIL is offline   Reply With Quote
Unread 03-09-2021, 04:25 PM   #47
redlude97
good idea on the window spline! Figured it would be easier to flush cut the pipe and install the flange on top of the tile after
Hai
redlude97 is offline   Reply With Quote
Unread 03-09-2021, 04:36 PM   #48
BIGPHIL
BIGPHIL's Avatar
Yes, absolutely. Just thought the picture was funny
Phil
Unread 03-10-2021, 07:37 AM   #49
I thought the same. "Whoa, now that'll be quite a throne!"
Unread 03-23-2021, 03:44 PM   #50
redlude97
Hey all, back after almost getting the floor in. I was cleaning out the grout joints with a utility knife and scraper and managed to somehow leave some metal behind on the tile
I tried buffing it out with a microfiber and magic eraser but no luck. Since the tile is a porcelain glazed matte surface I don't want to polish it too much to change the shine. Anyone have any ideas on the best way to remove this without affecting the finish of the tile? Thanks again
Hai
Unread 03-23-2021, 05:22 PM   #51
Gozo
I’ve had luck with BonAmi and Cerama-Brite. Both have effective abrasives without scratching. If you have a spare piece of tile you can use it as a test piece.
Jeff
Unread 03-23-2021, 05:29 PM   #52
redlude97
great idea! I have some cerama bryte for my cooktop
Hai
Tile over Tile Bathroom Floor-1st Project lorenk2 Tile Forum/Advice Board 4 06-15-2020 08:51 AM
Tile substrate for bathroom stone tile Rymatt Tile Forum/Advice Board 3 12-03-2012 05:04 PM
Bathroom shoe mold - tile walls, vinyl over tile floors HAPPYGRANDPARENT Tile Forum/Advice Board 8 05-01-2011 07:49 PM
Bathroom Tile RW Tile Forum/Advice Board 5 08-06-2009 05:17 PM
bathroom renovation - contractor is laying new tile over old tile - is this right?? txtree Tile Forum/Advice Board 2 11-01-2005 04:36 PM
