Unread 06-27-2017, 09:09 PM   #1
Bobtail2
Bobtail2's Avatar
Grout for marble tile backsplash with 3/16" space
I have a marble tile backsplash that has 3/16" space between the tiles. My understanding is that I should use a non-sanded grout for marble to avoid scratching the tiles. However, I am concerned about using it for the mosaic because I thought it should be used for 1/8" or less to avoid problems with shrinking.
Attached is a picture of a portion of the marble mosiac, which comes on 12x12 sheets.
Thanks for any advice,
Cathy
Cathy
Bobtail2 is offline   Reply With Quote
Unread 06-27-2017, 09:20 PM   #2
I'd recommend you use sanded grout if you can, Cathy. Make up a little test board with some of your tile and test your chosen grout on it. Some grouts will scratch more than others.
Those joints look more like about 1/8th" to me, and on a backsplash you can probably get by with un-sanded if you really have to, but I'd still recommend sanded if you can use it without harming your tiles.
You might wanna try one of the newer single-component grouts such as MAPEI's Flexcolor CQ or Custom's Fusion Pro. Don't think either will scratch your tile and either can be used in joints from 1/16th-inch to 1/2-inch.
Unread 06-27-2017, 09:22 PM   #3
tatumjonj
I'd say based on the tape measure sitting there and the great photo those grout joints are 1/8" pretty much on the nose. I'm sure somebody can recommend a grout that is lightly sanded suitable for that material.
Jon
Unread 06-27-2017, 09:34 PM   #4
Bobtail2
Bobtail2's Avatar
If you have done a similar project, what have you used in the past that worked well without scratching the polished marble?
I was considering using Mapei Ultracolor Plus grout on this, which is sanded. Has anyone ever used this with polished marble and did it scratch?
Cathy
Unread 06-27-2017, 09:52 PM   #5
wwhitney
The tape measure reads 3/32" for the gap. (Edit: or maybe 7/64").
Cheers, Wayne
Wayne
Unread 06-28-2017, 04:29 AM   #6
Karls tile Inc
Tile and stone contractor Tile setter
Sanded. Most of the newer high performance grout use smaller sand particles which results in a smoother fuller grout joint.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Unread 06-28-2017, 05:07 AM   #7
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
Edit. (You guys are right. Ignore this post. But I will leave it so that you can laugh)
Remind me to never let most of you guys measure for me. That is not an 1/8th of an inch. More like a sbch under a 3/16th.
I wouldn't use non sanded grout unless it says that it's good for grout joints that big and its the look that you are going for. I would use sanded. Maybe pick a brand that has fine sand in it.
I am neither clever or funny
Travis
It's just a clever handle.
Unread 06-28-2017, 06:27 AM   #8
Bobtail2
Bobtail2's Avatar
Can anyone recommend some brands with find sand?
Cathy
Unread 06-28-2017, 06:48 AM   #9
nelsonkoehn
showers & more
nelsonkoehn's Avatar
Are you holding your tape to the screen? Maybe you should adjust the zoom level.
Nelson
tile.nkoehn.com
nelsonkoehn is offline   Reply With Quote
Unread 06-28-2017, 07:50 AM   #10
JerseyDIYguy
I used Tec Powergrout on a marble mosaic floor with grout joints as small as 1/16" and had no issues at all. You can see some pics here:
http://www.johnbridge.com/vbulletin/...9&postcount=56
And closeups here:
http://www.johnbridge.com/vbulletin/...0&postcount=13
The Powergrout has fine sand in it. I used honed marble rather than polished, but I don't think that the fine sand would cause problems even with a polished surface. Give it a try on a test board.
Warren
Unread 06-28-2017, 08:30 AM   #11
CaliGrown
CaliGrown's Avatar
Bostik's Hydroment , Laticrete's Permacolor are cement based grouts that will accommodate from 1/16" and beyond.
Christopher Machado
1 (916) 990-1751
Unread 06-28-2017, 08:58 AM   #12
wwhitney
I'm going with 13/128". :-)
Those bottom markings on the tape measure are 1/32" markings, not 1/16" markings, so it is close to 3/32".
Cheers, Wayne
Wayne
Unread 06-28-2017, 09:08 AM   #13
prodjsaig
I have heard good things about flexcolor cq. a non portland based grout but if you can get cement grout from a place that sells a lot of it that would be my choice. Im always leary about buying grout from hardware stores because they dont turn over the products enough (at least not in the non popular colors)
other than that just preseal your tiles you can even prewet them before grouting. also when doing your lines you can avoid doing the serpentine wiping and carefully fill your lines.
Colby
prodjsaig is offline   Reply With Quote
Unread 06-28-2017, 09:19 AM   #14
prodjsaig
sorry by prewetting i meant when you go to do your first grout rinse you can spray it lightly with water to make it easier to clean up. a very light spray. you may even not want to do that because you dont want to wash out anything
Colby
Unread 06-28-2017, 09:25 AM   #15
nelsonkoehn
showers & more
The thing about CQ is that it's next to impossible to get a full joint on a sharp edged tile like that. Unless you'll let the grout set until firm. But then you'll have a latex film that will need to be scrubbed off. Which somewhat defeats the selling points of that grout.
CQ is my go to grout with most porcelain or ceramic tiles.
But,
I've nearly crossed out CQ when used on natural stone. For me there is more cons than pros. Cleanup especially. And then the no sealer point, but the tile needs a sealer, so ... And has anyone successfully grouted CQ on travertine.
If it were me I would try Mapei UltraColor Plus FA, with a light touch. It may scratch, but I think not. This is a fast acting grout tho, needs to be cleaned up in 15-20 minutes. If you'll wait until the end of the cleanup period you should end up with mostly flush/full joints.
Nelson
tile.nkoehn.com
Darkening grout/tile on tumbled marble backsplash (pre-grout sealant used) NovicesRus Cleaning, Restoration and Sealing 1 03-13-2008 09:24 AM
Grout space between tiles - 1/4" or 3/8" epb Tile Forum/Advice Board 5 10-06-2007 12:32 PM
Space or No Space 18" Granite Tiles Nancy Short Tile Forum/Advice Board 4 07-02-2006 07:52 AM
Tiling backsplash - 1/4" space tween counter and wall? playdirt107 Tile Forum/Advice Board 12 04-19-2004 08:06 PM
sanded grout on 1/8 " grout space? gailm Tile Forum/Advice Board 11 08-21-2003 01:11 PM
