Unread 05-31-2017, 08:05 PM   #1
mark999
glass mosaic accent wall
I have a wall 5ft. wide x 8.5ft. tall wall using glass and stone mosaics on a 12x12 sheet. This is not a wet area.
1) can I use "tec" universal mastic so I can complete it in one day?
2) If I must use thinset how far up can I tile where the tile will not buckle?
I have used universal mastic in non wet areas with great success. It has great adhesion and non sag properties.The next day tiles are bonded and the mastic is hard. I just do not know if it will be suitable for this project with the glass.
Thanks for any input
Mark
Unread 05-31-2017, 08:13 PM   #2
rmckee84
rmckee84's Avatar
I wouldn't, I'd use a quality non sag thinset like ardex x77, laticrete Tri lite, or even customs pro lite. You say it has stone and glass, mastic doesnt mix well with stone you run the risk of oil from the adhesive bleeding through the stone. That's just one hacks opinion though...
Ryan McKee
Unread 06-02-2017, 01:17 PM   #3
Sharon @ LATICRETE
Sharon @ LATICRETE's Avatar
Hi Mark,
We'd suggest not using a mastic with glass tile ever. It may seem to bond well initially, but over time it will likely disbond from a material like glass. As long as you are going over a suitable substrate, we would suggest using LATICRETE Glass Tile Adhesive, or 254 Platinum (White), and then a non-sanded grout to prevent scratching the face of the tile.
We don’t understand the question about how far up can I tile where the tile will not buckle?, But, you can go as high up as you want with either thinset, and it won’t buckle… Hope this helps, if you have any additional questions, please feel free to reach out to our technical team at 1.800.243.4788.
Sharon@LATICRETE
www.laticrete.com
Sharon @ LATICRETE is offline   Reply With Quote
Accent Mosaic CHAPAERO Tile Forum/Advice Board 1 02-27-2014 12:10 PM
Glass Mosaic / Kerdi shower wall FoolsRushIn Tile Forum/Advice Board 12 02-22-2014 10:40 AM
Glass mosaic tiles on exterior wall. mrdonut Tile Forum/Advice Board 2 03-29-2012 09:23 PM
Glass mosaic as accent jwebster Tile Forum/Advice Board 4 04-02-2011 06:01 PM
Full wall w/glass tile mosaic Betasig588 Tile Forum/Advice Board 6 03-06-2011 06:47 AM
