Unread 06-22-2015, 06:45 PM   #1
pooky
pooky's Avatar
permacolor select colorant as thinset tint
howdy folks,
question: can I use permacolor select colorants in my white thinny
in advance of grouting with a similar color.
-- in this instance I am using silver shadow (laticrete) spectralock in 1 inch hex and then it occured to me??
-- self, I thought, inevitably, even with a brush to clear joints there is always some peek-through of thinny . . . wonder if I could use the "select" colorants
to minimize that small issue??
I know select has a powdered sealing component and do not know if it is in the solids or the colorant??
anyone?? rothberg, nash??
Stephen -- Man vs. Tile -- The Battle Continues . . .
pooky is offline   Reply With Quote
Unread 06-22-2015, 08:01 PM   #2
Jc0379
Josh B & S Home Improvement/ Owner
Stephen at the recent Laticrete PTK I was told that they are in the process of testing Permacolor Select colorants with 254 platinum, kinda like the one step method. I would say go for it!
Josh
Jc0379 is offline   Reply With Quote
Unread 06-24-2015, 12:41 AM   #3
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
The rumour I heard is mix two packets with the 25lb bag of glass tile adhesive.
Would be usefull for setting paper faced glass tile.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Laticrete New Products: Permacolor Select and Plasma Grout jadnashua Professionals' Hangout 143 09-18-2019 06:41 AM
Trouble with Permacolor Select Expresso Grout JessicaTX Tile Forum/Advice Board 6 05-26-2015 04:27 AM
How to stain or tint travertine tile stairs darker stacian Tile Forum/Advice Board 2 09-20-2011 06:31 PM
glass mosaic grout tint, seal and...epoxy float? jonesthought Tile Forum/Advice Board 4 09-19-2009 01:22 PM
Can I tint thinset? PharmD Tile Forum/Advice Board 6 05-23-2009 07:33 PM
