Unread 09-20-2014, 10:19 PM   #1
aartrace
Jeffrey Court crackle glass tile mosaic-how to cut
I'm in the middle of doing a backsplash out of Jefffrey Court Benevolent Blend Mosaic tile, which is a combination of slate, and crackled glass over ceramic. The layer of crackle glass is very thin, and attempting to cut it with a standard wet saw blade results in the glass wanting to chip out back to where it last crackled. The same goes with using a diamond dremel blade (not quite as bad though). I'm about to go up and over the window, which will require a lot of cuts, but also have the time constraint of the owners come back into town tomorrow night (i.e.: can't order anything, or drive to the nearest big city for a new blade). Any suggestions? I read in several places on the forum that crazy glue was a good way to go....just put it on your cut line, and then scrape off the excess afterwards?? Thanks for any suggestions, I really appreciate it!
Tracy
Tracy
aartrace is offline   Reply With Quote
Unread 09-20-2014, 10:50 PM   #2
BrJr
My Dad used to do stained glass windows. Sometimes he would cutcertain types of glass that appeared to have cracks in it. He would take masking tape and cover the glass piece front and back, then make his cut. He would also use a little oil on the blade.
Sorry if it's not much help, saw your post while asking a question myslef. good luck
Briscoe
BrJr is offline   Reply With Quote
Unread 09-21-2014, 07:41 AM   #3
Cain
Cain
Try a hand cutter.
I just did too crackle back splashes in a row. Neither were that brand tile, but cuts came out clean except u cuts around outlets. Outlet covers took care of that though.
Tape may work. Have fun.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Unread 09-21-2014, 05:21 PM   #4
try this
Do u need a saw 2 cut 1" glass tile mosaic? HomeDepotAssociate Tile Forum/Advice Board 15 03-26-2011 03:31 PM
Looking for Mega Cera - Crackle Vanilla Glass 1x1 cschickgo Tile Forum/Advice Board 0 07-15-2010 02:21 PM
tantrum crackle glass tile burbackbuilders Tile Forum/Advice Board 4 06-18-2008 08:00 PM
How to cut Tantrum mosaic glass tile in half cmjindy Tile Forum/Advice Board 1 04-24-2006 10:29 PM
How to cut face paper mount glass mosaic? carolyn53562 Tile Forum/Advice Board 4 02-10-2006 08:16 AM
