Unread 02-07-2014, 09:01 PM   #1
feggymango
Can you use servolight with Kerdi
Has anyone had any luck with using servolight thinset with kerdi, going over new drywall, tile is going to be 12-24. I know that schluter recommends unmodified but heard info that servolight cures/dries in a different manner than modified thinsets and would be alright to use. Just about to start a shower and they already have a bag of the servolight there
Jeff
feggymango is offline   Reply With Quote
Unread 02-07-2014, 09:16 PM   #2
Not familiar with that brand, but if it is a rapid set mortar, if you call Schluter, they will allow it. If not, you're on your own. Depending on the tile, it could take months for a normal modified thinset to dry and cure properly. Unless you're a pro, most DIY'ers will have problems with a rapid set - some of them start to cure in 20-minutes, so your pot life is very short.
Unread 02-07-2014, 10:15 PM   #3
Metamorphic
I have used servolight many times over Kerdi without a problem. You will void any warranty from Schuller but the tile will stick no problem. If using it under the kerdi you need to add more water to your mix. Drywall should be taped and primed.
Dale
Better with mud and tiles than computers and smartphones.
Metamorphic is offline   Reply With Quote
Unread 02-08-2014, 10:11 AM   #4
wilander
i used servolight in my kerdi shower as well. it's only slightly modified so i had no issues using it. it's a good quality thinset.
Richard
wilander is offline   Reply With Quote
MY 1st Kerdi Shower, what do you guys charge for installing kerdi Steven Tiler Professionals' Hangout 13 05-05-2014 08:07 PM
Adhesives question: Swanstone, Kerdi band, Kerdi aluminum edge profiles keithwwalker Tile Forum/Advice Board 8 02-19-2012 08:54 AM
Laticrete 317, Kerdi membrane and Kerdi shower pan pcoonrod Tile Forum/Advice Board 6 06-15-2010 03:32 PM
Opinions on the Kerdi tray and curb? Using DensArmor under Kerdi? danelectro Tile Forum/Advice Board 1 08-27-2008 06:30 AM
Kerdi drain near edge of shower and Noble ProSlope vs. Kerdi Tray vs. mud Hickory Tile Forum/Advice Board 8 12-07-2005 03:42 PM
