Unread 09-14-2018, 12:36 PM   #1
spta97
Granite/Marble over Kerdi/Ditra set time before caulking
Hi,
Quick question hopefully. I am installing a granite window sill in the shower going over Kerdi using unmodified thinset. Once I install, I will be caulking around it where it meets the window and tile.
Schluter says it’s ok to caulk as soon as I install (no cure time for the thinset). Is everyone in agreement?
I’m planning on frog (green) taping around the caulk bead to get a sharp line and just a little worried I might shift the granite as I’m pulling it off as unmodified tends to be less “grabby” (though the granite sill is 17lbs).
Same question for a threshold (on top of ditra or concrete).
Summary: Should I allow cure time of unmodified thinset for thresholds/granite before I caulk? If so, how much?
Tom from Long Island
spta97 is offline   Reply With Quote
Unread 09-14-2018, 01:49 PM   #2
rmckee84
rmckee84's Avatar
I would give it a little time to set up if it were me, personally I wait until the next day. Taping off is fine, but I'll offer a little tip with silicone...if you just run your bead then spray with Denatured alcohol or aerosol glass cleaner and tool the joint it makes it really easy. The silicone won't stick to anything that has the glass cleaner or alcohol on it.
Ryan McKee
Unread 09-14-2018, 02:13 PM   #3
spta97
Thanks. I was thinking a little time couldn’t hurt
I typically will use denatured alcohol but never had good luck with the tools.
Any trick for going around inside corners without stopping? I have to caulk around the sill and entire window so I have two places where the caulk goes three different directions
Unread 09-14-2018, 02:25 PM   #4
rmckee84
rmckee84's Avatar
Not really, a caulking tool, my finger, and Denatured alcohol is all I ever use.
Ryan McKee
Unread 09-14-2018, 04:03 PM   #5
A typical unmodified should be fine to play with the thing after a couple of hours. You wouldn't want to put any weight on it then, but it shouldn't hurt anything to caulk. I'd read the instructions on the caulk you choose, as they may have a minimum timeframe listed...some won't bond well if the surface is still damp which, if you just set the thing and then sponged it clean...there could be excess moisture there.
Unread 09-14-2018, 05:36 PM   #6
spta97
Thanks for the reply. I’ll probably give it to the next day before I caulk.
For reference, I’m using Tec unmodified uncoupling mortar (Lowe’s) and ColorRite Color-Sil for the finish caulk which is an RTV silicone.
The granite window sill is about 48” x 4” x 3/4” thick.
Unread 10-15-2018, 09:20 PM   #7
spta97
Another question related to the project.
Does anyone know where I could get black granite in a quarter round configuration either 3/4” or 1”?
I’ve seen small pieces in 1/2” (small = 12” long - would prefer one 4’ piece) but looking for something to cover a gap.
My granite guy doesn’t have it and I can’t seem to find it online or in box stores.
Unread 10-15-2018, 10:53 PM   #8
Have you considered having a tile profiled? It's not cheap if you have it done. It's possible to do it yourself, but it takes some tools and skill and a fair amount of time. Keep in mind that a quarter round will weaken the stone a fair amount and if it's near an edge that might get some abuse, a metal profile on an edge would be more reliable.
Unread 10-15-2018, 11:57 PM   #9
Tom,
4' long pieces of quarter round won't be found at the store. It would need to be custom fabricated at a fairly pretty penny.' I think profiling your own material, as Jim suggested, might be something to consider.
You can always shop at a tile shop for some tile trim pieces that might work out for you.
Unread 10-16-2018, 05:16 AM   #10
spta97
Thanks for the replies.
The reason I need it is the granite window sill’s height did not let it sit flush on the backside so I’ve got a gap that is about 1/2”. I used to have tile there but it is no longer available and the solid piece looks better.
Quarter round would be perfect, but I can also use a 1” square block.
The latter should be just a matter of cutting from a strait price so hopefully my granite guy can do it.
Technically I could use tile but it is going on top of granite with the back up against the window so any install will be silicone.
Underneath the sill is waterproofed so this is just cosmetic but I don’t want to create a place where water can sit.
I suppose I could use quarter round made out of vinyl to make it look like part of the window. I’m sure that exists.
Minimum dry time before re-sealing and caulking travertine bath? bdobs Cleaning, Restoration and Sealing 6 05-19-2013 09:44 PM
New Project Lots of question - First time tile & kerdi/ditra Oz07 Tile Forum/Advice Board 22 04-22-2010 08:04 AM
Ditra and Marble/Granite MODIFIED mortars Aquera Professionals' Hangout 30 01-30-2010 06:50 AM
How should I install marble over Ditra and Kerdi? BenInWI Tile Forum/Advice Board 8 01-05-2010 11:09 PM
Marble or granite on Kerdi membrane trihai Tile Forum/Advice Board 3 04-22-2007 12:37 AM
