Unread 01-05-2009, 08:08 PM   #1
Doitall
First Shower Build
Hi I'm new to this forum and to ceramic tile installation. I will be building my first ceramic tile shower and am currently researching the Kerdi and Wedi systems. My first question is on water supply lines. What is the typical wall thickness after backerboard thinset and tile? Do most plumbers leave a female thread inset in the wall to thread a brass nipple into after the tile is complete or do they put the nipples in prior to tiling? I'm using Moen products and the instructions for the body spray give a tolerance of 1/2" to 5/8" protusion from the finished wall surface.
Thanks in advance for any help.
Doitall is offline   Reply With Quote
Unread 01-05-2009, 08:12 PM   #2
davem
davem's Avatar
Hi Do, welcome to the forum. I'll let the pro's answer, I just wanted to say hi.
davem is offline   Reply With Quote
Unread 01-05-2009, 08:21 PM   #3
custombuilt
most of the time the plumbing is stubbed out already when i tile.... install cbu around it and tile around
Jason W.
Superior Construction
Quincy, IL
Unread 01-05-2009, 08:31 PM   #4
Welcome aboard, Doitall. Please give us a first name.
For the shower head you use an "eared" ell inside the wall. You screw in a temporary half-inch pipe nipple with a cap on it. After tiling and grouting you will remove the temporary nipple, the "stub out" and replace it with a nipple of the correct length for your fixture. Here is a picture of the eared ell with the temporary nipple screwed into it.
Unread 01-06-2009, 04:21 PM   #5
Doitall
Thanks John the name is Dave. Should I figure an inch for wall thickness to set the valves that have no nipples.
Unread 01-06-2009, 04:44 PM   #6
muskymike
muskymike's Avatar
Hi Dave, you hafta know what your tile thickness is and the sheeting (CBU or drywall if using Kerdi) before you set the valve. There should be a plate that is on the valve that shows you where to set it to the finished wall .
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Bob's Curbless Shower Bathroom Remodel Bob V. Tile Forum/Advice Board 33 09-15-2008 06:42 PM
Frequent DIYer, need help planning shower re-tile chowfun Tile Forum/Advice Board 11 11-20-2005 10:29 PM
Please Help -- Leaking Acrylic Shower Base Ricketty Rabbit Tile Forum/Advice Board 5 07-22-2005 10:36 AM
Completed Project w/ Lessons Learned brianp Tile Forum/Advice Board 21 05-25-2005 12:12 PM
Kerdi shower questions TTurner Tile Forum/Advice Board 8 02-09-2005 10:29 AM
