Unread 09-02-2019, 06:43 PM   #196
Themus
Yes the bull nose edge and the painted wall.
Not sure what you mean by the 95% coverage. The tile sits on top of Hardie Backer, with a Schluter Kerdi Membrane.
Thomas
Themus is offline   Reply With Quote
Unread 09-02-2019, 06:55 PM   #197
The 95 percent is the amount of the back of each tile that is supposed to be covered by thinset mortar after the tile has been set. That is the bond between the tile and the Kerdi membrane. It's a difficult standard to meet, but you want to get as close as you can.
The bullnose edge/outside wall joint should, technically, have been filled with a flexible sealant, but it's common for folks to grout that joint. Problem with grouting is that it will quite likely crack before long. The sealant will flex a bit with the differential movement.
Unread 09-03-2019, 05:57 PM   #198
Themus
Sounds like then my thoughts about caulking along those two edges is a good idea. Basically I would be doing what you suggest he should have done. I'll caulk it flush to the edge. Right now the grout as I mentioned is a bit shy of it.
Thomas
1st bathtub to shower conversion and bathroom remodel arnav Tile Forum/Advice Board 281 08-04-2015 06:41 PM
Help with tub to shower conversion loudgonzo Tile Forum/Advice Board 72 05-30-2014 08:26 PM
Tub to Shower Conversion chrsdrshm Tile Forum/Advice Board 51 04-14-2014 09:29 PM
Conversion from old bathtub to new tiled shower enclosure fearlessyp Tile Forum/Advice Board 13 08-13-2006 10:19 AM
Bathtub to Full Shower Conversion Big Bill Tile Forum/Advice Board 9 07-26-2002 07:53 AM
