Unread 05-23-2013, 12:45 PM   #1
nflores07030
Newbie - hiring a contractor to retile shower - NEED HELP
Hi,
So I made the mistake of hiring a guy (contractor) to do a retiling of my shower in my bathroom without doing my homework on what that job requires so I can manage his work. And I am sure everyone who is out there who does this for a living probably hates to be micromanaged, so please do not think I want to do this...I just want to make sure he is installing this correctly to avoid problems in the future. I found out the other day that he put drywall up (to the studs) and according to him he was going to put cement board on top of the drywall. I stopped the project after doing some research and finding out Drywall is a big NO NO. He explained to me he needed something under the cement board (not sure why since many people say just put the cement over a plastic barrier over studs). But I think because of a gap between the floor pan and the wall. I instructed him to remove the drywall and if he felt he needed something behind the cement board - then at least use greenboard not drywall with a vapor barrier (6 mil plastic).
So here are my questions:
1) what is the best or preferred way to do this - meaning to waterproof? I am petrified about leaking and mold and I do not want this to be a job I tear down or have to redo in the future not to mention the liability issues if I do get a leak or the safety issues for my family's health if I get mold. The contractor has been in the business for 30 yrs and is skeptical to listen to me.
A) greenboard, vapor barrier, and cement board (Durock or Hardi - does it matter)? ** Is there any danger to using greenboard under cement board so long as I use the plastic barrier?
B) cement board and liquid membrane over board to waterproof (redgard, laticrete/hydroban, etc..) no plastic behind
C) Kerdi system (what goes under Kerdi, is it cement, drywall under Kerdi?) or another sheet membrane system.
Flor
nflores07030 is offline   Reply With Quote
Unread 05-23-2013, 01:12 PM   #2
Flor,
First off - pictures. We so love us some pictures.
Second, I concur - a drywall+cement board sandwich only invites moisture problems. Instead of DW to make up the gap he shouldda used some firing strips or other correctly sized lumber to make up the difference. Then poly sheeting, then cement board.
But, ifn all y'all are that worried about mold I'd be inclined to opt for a surface applied membrane; RedGuard, Hydroban, etc-etc. In that case, cement board right to the studs - no poly behind, tape and mud the joints as usual, then whatever number of coats the manufacturer of the membrane specifies.
This is a shower, not a tub surround, Jah? What about the pan details?
Unread 05-23-2013, 01:20 PM   #3
nflores07030
Pictures
Here are the pics of the drywall, the other side of the shower without the drywall and the frame.
Flor
Unread 05-23-2013, 01:27 PM   #4
Huh, silver seam tape is a new twist, not seen that before.
Need a coupla pics of the shower base, Flor.
Unread 05-27-2013, 08:18 PM   #5
nflores07030
Greenboard then Cement/Hardi - how to waterproof
So I think we decided to pull ou the drywall for obvious reasons, but since we still need something for support and to fill in the gap, we opted for Greenboard. I know greenboard is not recommended in showers but we will be putting cement board on top. What is the best waterproofing? Is it vapor barrier between greenboard and cement board (4-6 mil plastic), or can I adhere the cement board directly to the greenboard and then use a liquid waterproofing?
Flor
Unread 05-27-2013, 08:24 PM   #6
To better answer your questions we need to see the shower floor.
What ya got going on there?
Newbie about to choke my friend/contractor Inkedbliss Tile Forum/Advice Board 23 05-24-2011 02:33 PM
110% newbie attempting kitchen retile markns Tile Forum/Advice Board 2 06-09-2010 02:02 PM
Before hiring a contractor, read this! tilerite Tile Forum/Advice Board 0 12-25-2007 09:42 AM
need help hiring a contractor redrob Tile Forum/Advice Board 6 09-12-2007 03:27 PM
Newbie ? - Bathroom retile woes Sam Hill Tile Forum/Advice Board 2 09-04-2006 09:21 AM
