Unread 01-16-2011, 02:13 PM   #1
namsaev
Beveled subway tile, how to end it?
I'm using 2X4 in polished beveled marble subway tile as my kitchen backsplash. The bevel is pronounced. The thickness as the edges is about 50% of the middle. But how do I end it? Apparently there are no 2X2 in end pieces available.The counter top will be an L-Shape. I plan on starting where the cabinets do a carrying it to courner. Ending in the corner shouldn't be a problem. But how I make a vertical line from the bottom of the cabinets to the counter has me puzzled. Spliting the tile into 2 in squares will leave me with a non beveled edge on one side. Mitering a piece (three actually) I think would look a bit odd.
I could do a grind on the cut edge to match the bevel. But if I do that how hard is it to polish it? The marble is definitly high gloss.
Allen V
namsaev is offline   Reply With Quote
Unread 01-16-2011, 02:34 PM   #2
Shaughnn
Trowel Monkey
Shaughnn's Avatar
hi Allen,
Yes, you could replicate the bevel on your cut pieces. That would require that you buy some polishing equipment and do some practicing however. An alternative would be to contact a local fabricator and ask if they will do this for you, for a fee of course.
As your project sounds like it's only got a single outside-corner, there is another option though. Lay out your tile and find the sweet spot where the running-bond pattern can be cut at a uniform height. Using a quarter-round at the corner would then flow smoothly. There are indeed firms which are manufacturing polished quarter-rounds from marble, though you'll have to find a supplier local to yourself. I've found them here in Seattle at Tierra Sol, a regional distributor.
Best of luck,
Shaughnn
Unread 01-17-2011, 10:16 AM   #3
CanyonTile
Finish off with trim pieces that match your marble:
i.e. Pencil liners, Chair Rails, Dome Liners, Cigaros, etc.
Go to your local tile store and see what they have that you could use, trims are available in all sorts of different cuts.
Good Luck!
Gabe
We Got You Covered
www.canyontileandstone.com
CanyonTile is offline   Reply With Quote
Beveled Granite Tile jlsddmar Tile Forum/Advice Board 4 01-12-2010 02:40 PM
Beveled Edge Subway Tiles - finishing edges? Pakyd Tile Forum/Advice Board 11 10-03-2009 10:12 PM
Grouting 4 x 8 "beveled" subway tiles in shower Page Professionals' Hangout 4 02-06-2009 07:06 AM
Cutting tile with beveled edges jnbrown Tile Forum/Advice Board 13 12-20-2008 01:11 PM
Outside Corner with Beveled 3x6 Tile Sommars Tile Forum/Advice Board 9 03-03-2006 05:28 PM
