08-04-2010, 02:02 PM
Tile Magician
Best way to apply sealer????
i kno your supposed to brush, roll, whatever the sealer onto the tile but i want to know what process has been more efficient end maybe easier as far as sealer application. some pictures may even help better. i just want to get really good at applying sealer
Oscar
Ranger Tile and Stone
oficially schluter-ized by Les Garey!!
innovating tile installation in austin tx....me vs fiberglass pans war
08-04-2010, 02:15 PM
You say applying sealer to tile. Do you mean stone or marble tiles? What about grout?
Ben
08-04-2010, 04:17 PM
Tile Magician
travertine mostly, and both i like doing a coat of enhacer before grout and penetrating sealer after grout
Oscar
08-04-2010, 04:20 PM
Travertine isn't that porous, especially in the high hone it usually comes in. You dont need that much sealer, its easy to over-apply and make more work for yourself.
for normal areas, I use a microfiber mop. Dip it in the sealer and rub it on the side of the bucket until it stops dripping. aply a thin, even coat. 10-15 minutes later buff off the excess. I use a floor machine with a red pad and terry towels under the machine. this is the fastest most effecient way. Wool bonnets work, but get residue built up.
08-04-2010, 04:24 PM
I always used a lambswool applicator (no roller) or painters pad. I don't use rollers.
Ben
08-04-2010, 04:25 PM
I use a paint pad from Home Depot for stone and for tile grout joints I like the bottle that has the small wheel on it at HD.
08-04-2010, 07:56 PM
LT
I use a spray bottle when sealing stone.I get a box of new rags and wipe afterwards,not using the dirty part of the rag too much.You know,kinda like folding it int 1/4s and making use of all 4 sides then I discard and grab a new one.
When just sealing grout,I like the lil tube w/thebrush head/but not the one that already has sealer,I like to use my own which is usually Dupont's Bulletproof.The one w/the wheel works alright but seems like too much comes out at times.Same thing,though w/either method-clean rags are a must.might bwanna consider some surgical gloves and some respirable protection.Protect those lungs!!
*L.T.*
tandctile-dot-net
2nd generation tile installer
08-05-2010, 03:39 AM
STT Owner
