Unread 02-07-2021, 12:34 PM   #1
Charles Mulford
1/2" masaic tile added above existing backlash
MY existing 4x4 tiled backsplash did not meet the new quartz counter I had installed. I now need to fill in the 3/4" space between the existing backsplash and the quartz countertop. I have 1/2" marble mosaic tiles to fill this space - Can I use adhesive silicone caulk to attach the tiles, and also use it as a grout to insure that it is waterproof?
Chuck
Charles Mulford is offline   Reply With Quote
Unread 02-07-2021, 02:28 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
I'm guessing you removed 1.5" of countertop and replaced with 2cm quartz?
If that's the case, I might approach it a little differently. I'd shim the top of cabinet to correct height for existing backsplash to match up, then make a piece of trim to cover the shim(s), I've even done this with a prefinished spacer that was just a little bigger than cabinet so there was a reversed stair step from cabinet to countertop overhang.
In my minds eye the insert you're planning will call attention to itself, but I'll admit to looking at this through a cabinetmaker's eyes.
Peter
1/4" backer over existing 1/2"? MP_ Tile Forum/Advice Board 5 02-19-2011 10:03 PM
Adding a "ladies ledge" to existing shower. macpherl Tile Forum/Advice Board 8 11-07-2010 08:11 PM
Neighbor Advised to "Tile Over" Existing Shower Floor Tile? John K. Tile Forum/Advice Board 8 02-11-2009 10:44 PM
Stone on 1-1/8" plywood--what to do with existing 1/4" overlayment under old vinyl? rlpenny Tile Forum/Advice Board 4 12-28-2007 09:40 PM
New floor 3 1/2" above existing slab AnotherMikey Tile Forum/Advice Board 1 05-16-2006 07:58 AM
