hi all,
awesome site and thanks for helping us DIYers. i plan on redgarding entire shower or maybe not the floor depending on your answer
i completed the preslope with chicken wire and its just under 1/2 inch thick at the drain, but havent installed the cement board walls yet or applied any redgard yet. i did put plastic sheeting under the preslope to keep the moisture from the preslope mud being soaked by the subfloor. i also have an outside wall with vapor barrier over insulation. i was planning on doing the traditional pvc liner when someone told me about the divot method which led me to question best method now.
1. custom building products told me that redgarding the outside wall which already has the vapor barrier will not cause any issues with mold (mold sandwich) whats your thoughts?
2. is the plastic sheeting under the preslope any concern for a mold sandwich when the pvc liner or redgard is applied over the preslope?
3. do you recommend the divot method over the pvc liner? if so, can i just add the additional layer of mud on top of the preslope and use a bonding agent in the mix instead of water? if not, i can rip out the preslope and start over.
4. when i install the cement board walls, is it ok to sit them on top of the pan since it will be redgarded down and over the floor, with 6" membrane fabric?
thanks again
5. if i just use redgard and not pvc liner then it would be easier over the curb as i could install cement board there too and redgard. if i do pvc liner over curb, whats best way to secure cement board to the curb over the liner?
6. should i scrap the redgard and pvc idea and do a sheet membrane like kerdi on the floor/curb up to the walls with a membrane fabric transition with redgard up the walls?
thanks
