01-14-2021, 08:10 PM
Mike's Upstairs Shower Project
Hi,
I am getting ready to install a kerdi board shower surround after removing an old fiberglass tub/shower surround. There is an electrical wire on a GFCI which was in place for the whirlpool pump for the old tub. I would like to re-purpose this wire for a light in the ceiling of the new shower. The wire I am starting with is only approx 1.5 feet in length, meaning I have to add to its length to reach the desired location for the light. My intent is to put an electrical box on the stud wall and splice a new length of wire with the existing one inside the box and carry on. As this will be covered over shortly after with kerdi board, I want to make sure I consider all potential issues before I proceed.
Does anyone have an experience with wiring inside shower walls? Does my plan sound correct?
Thanks in advance
01-14-2021, 08:29 PM
A splice must be in a box, and the box must be accessible by code.
...... because if the slice ever pulled apart, let alone potential of electrical fire, you couldn't access it to trouble shoot future issues.
If you can trace the wire back a couple feet, maybe you could find a better location for the splice box where a cover plate wouldn't matter.
Sent from my SM-G950U using Tapatalk
Reason: Rude, caution issued
01-14-2021, 08:34 PM
Are you sure the whirlpool wire isn't 220?
01-14-2021, 08:49 PM
Welcome to the forum Mike. Nothing at all wrong with wiring inside a shower wall. Supposed to be waterproof so the wire doesn’t care.
100% agree with the other Mike’s post.
The code’s is what it is for a reason. I’d bet you can trace the wire back a bit to find an already existing junction box to run a full length single piece, or at least place a code compliant box to run from.
Short cuts (electrical or otherwise) usual just make for more headache in another section of the project. Do it right and do it safe the first time around. I never met anyone who was sorry they did it correctly. At least not anyone that was at least half sane...
And, yeah, check the 220 just to be sure.
Jeff
01-14-2021, 09:01 PM
CX, Any reason you edited my post and removed the part where I said this is illegal?
Because I said the action of doing something that is illegal and has killed people is other than smart? And didn't insult the person, I stated a fact about the action.
01-14-2021, 09:04 PM
I removed the parts where you called the OP stupid, Mike, and I sent you a PM explaining the action. Please don't do it again.
01-14-2021, 09:09 PM
I never called the OP stupid. Now you are defaming me. I said his plan would be illegal and stupid, not him. Aka illegal and"lacking good judgement"
It's an accurate statement and does not attack the OP.
01-14-2021, 09:17 PM
Welcome, Mike (Chrome71)
If you can't do as Jeff suggests, it's perfectly legal to add a box for your splice that is open through the side of the wall opposite your shower. You can simply put a blank cover plate on it.
01-14-2021, 09:22 PM
Just did a demo where there was a receptacle in the wall for a whirlpool w/ gfci adjacent to the shower. I was hoping to do something cool with the circuit such as run a steam generator, but in the end decided it was probably beyond my skill level, likely one of my few correct decisions in the process.
In the end I just had the circuit removed. For lighting it's easier to tie into an existing lighting circuit- no need to fish a cable up a wall, etc.
Mark
01-14-2021, 09:25 PM
If the OP's planning a KerdiBoard shower, Mark, I'm thinking chances are very good that his walls will be completely open and it'll be pretty easy to route wires to a ceiling light and a switch somewhere.
01-15-2021, 07:22 AM
I don't know of any electricians that like these, but they ARE approved.
https://www.homedepot.com/p/Tyco-Ele...specifications
In-wall splice with no junction box. Note, only modern non metallic romex.
01-15-2021, 09:42 AM
That's a new one on me, Mike, but 334.40B certainly does describe something like that for "repair wiring" if it is listed. I'll hafta ask my real electrician if he's used such devices. I can certainly see the value in situations like our OP is faced with and I have been faced with many times.
Reason: typo
01-15-2021, 12:12 PM
I think this article pretty much sums it up.
Phil
01-15-2021, 12:40 PM
I looked into those splicers when I remodeled my kitchen, Phil, and uncovered the same article you linked to.
01-15-2021, 01:18 PM
#15
whatever. Prove that any situation is NOT a repair. I wired a new run and i cut it too short. I now need to repair it.
The wording changed but it does not qualify why it did and the article is interpreting why, which is rather subjective.
The article's conclusion:
And the splice can only be concealed when it is part of a NM cable fished behind a wall or floor. The device is never permitted in an open stud space where drywall will later cover it during the finishing phase of a remodel, regardless of the Code cycle.
Does not make sense. It can only be used when finished behind a wall or floor, but never in an open wall that is later finished. So the solution is to finish the wall, then cut it open, make the splice, then close it up....
