Unread 03-04-2016, 07:21 AM   #1
Farrar1
Kitchen backsplash
Using 8mm glass tiles 1" squares on a 12x12 matt. They are being installed to painted drywall. My question is what type of setting compound should I use and should their be anything done to the drywall before install for better adhesion?
Farrar1 is offline   Reply With Quote
Unread 03-04-2016, 08:13 AM   #2
K_Tile
Member of Million SF Club!!
Any thinset mortar with "glass" in the name. They are creamier and stickier than normal thinset. No need to worry about prepping the drywall unless its a high gloss paint. If so then a quick scuff with sandpaper will help adhesion.
One of these Big 3 should be found at a big box store.
Custom Building Products....Glass Tile Premium Thinset
Laticrete......Glass Tile Adhesive Mortar
Mapei.........Mosaic and Glass Tile Mortar
Unread 03-19-2016, 11:57 PM   #3
Farrar1
Backsplash????
Size:  65.4 KB Doing a glass tile back splash my question is where would you stop it in this situation,at the edge of cabinet? Or take it on down the wall to the corner?
Unread 03-20-2016, 12:04 AM   #4
Sure looks like they would have installed a couple more cabinets to fill in to the corner. But, to answer your question, I would tile to the corner.
Unread 03-20-2016, 12:31 AM   #5
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
... and all the way to the ceiling
And maybe add a couple floating shelves while you're at it:
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Unread 03-20-2016, 12:41 AM   #6
Farrar1
Thanks for the reply that's kinda what I'm thinking also. The problem with adding more cabinets is that bar top is 42"wide access to any more cabinets in this spot would be hard. But I feel the same way it would look better imo.
Unread 03-20-2016, 12:54 AM   #7
Farrar1
Well the home owner has a big collection of roosters that will be on top they specifically wanted room on top for them and I did recommend adding shelves but they have a painting for that spot just hope it don't clash with the tile
Unread 03-20-2016, 06:55 AM   #8
I can see a painting helping out. I would make the tile go straight across from the bottom of the upper cabinets to the corner.
Unread 03-20-2016, 07:02 AM   #9
PC7060
PC7060's Avatar
What Adriana said. That blank area is crying out for a cool design element to balance out that peculiar cabinet arrangement.
Unread 03-20-2016, 07:07 AM   #10
Autoplay
Tile Setter
What Davy said.....run it to corner bead etc.
Rich
Unread 03-20-2016, 07:25 AM   #11
PC7060
PC7060's Avatar
That hammer on the stone is making me nervous. Maybe some type of surface protection is in order?
Unread 03-20-2016, 08:40 AM   #12
Farrar1
Sorry pc7060 I don't follow you maybe some surface protection may be in order??
Unread 03-20-2016, 08:55 AM   #13
HS345
Tile Contractor
HS345's Avatar
Just the hammer? The use of the brand new unprotected granite countertop as a work bench is what's making me nervous.
The name's Greg
Unread 03-20-2016, 09:00 AM   #14
CountryBumkin
CountryBumkin's Avatar
Send a message via ICQ to CountryBumkin
Would still look better, IMO. It just doesn't look complete (too crowed in the corner). Now is the time to add them if you're going to - and you could just them for those items not used on a regular basis. There are never enough storage places in the kitchen.
Good luck.
CountryBumkin is offline   Reply With Quote
Unread 03-20-2016, 02:57 PM   #15
PC7060
PC7060's Avatar
Greg, my point exactly, don't use a finished countertop as a work surface without some kind of protection (cardboard or rosin paper at a minimum). Initially thought it was some kind of fancy granite but looking at the pictures closer it may be Formica.
Kitchen Backsplash JackMac Tile Forum/Advice Board 9 10-12-2013 09:34 AM
Metal quilted backsplash or metal tiles? Kitchen backsplash Jasonn B Tile Forum/Advice Board 5 01-09-2013 02:31 PM
Kitchen backsplash bkandare@maxim Tile Forum/Advice Board 6 06-20-2006 07:30 PM
Kitchen backsplash cnrhome Tile Forum/Advice Board 11 01-28-2005 08:33 AM
Kitchen Backsplash... Okay w/ 4" ES backsplash? LPOWMACBACK Tile Forum/Advice Board 1 03-15-2004 07:17 AM
