Unread 10-22-2014, 03:50 PM   #1
zkm
Complete Master bath re-model
Hello everyone,
I am new to the forum, this is a great resource to have !!! Thanks everyone. Definitely not new to DIY though and bringing an occasional pro to help with work that I would likely screw up
We purchased a house earlier in the year and although I knew there were some short cuts taken I didn't think our master would give out this quickly. We found a leak in the shower wall and although we planned on re-doing it, this early wasn't the plan. So I have started researching how to build a seamless glass enclosed steam shower without a dam.
Our existing shower has a tiled floor on top of a slab, so I will need to demolish all the tile including the shower pan, move some plumbing around to open up more space for the shower. Our ceiling is also 7 feet and there is no way to make it higher.
So my question is what approach should I take to build this shower and how would i go about doing it on the slab once the tile is demolished. I've been researching Schluter Kerdi board, I am familiar with Hardiebacker.
All responses are appreciated. Mean while I will continue reading the board.
Yev
zkm is offline   Reply With Quote
Unread 10-22-2014, 04:53 PM   #2
Lazarus
Lazarus's Avatar
Kerdi is an excellent way to go. A properly built Kerdi shower is monolithic and should never leak. If you can find a tile technician conversant with the product, you should be a Happy Camper.
If you want to put a location in your information, you might well be able to find a "Pro" in your area.....
Laz...
Unread 10-23-2014, 12:11 PM   #3
zkm
I added my location.
If I wanted to do a curbless shower, once I demolish the existing shower and the existing tile floor. I will have a "flat" surface. The shower area will need a slope. So once the slope is built, I assume I will have to raise the outside of the shower tiles to the same level?
I also plan on doing radiant heating which will raise the floor some. What are the actual steps to do curbless shower?
Yev
Basement Bath Re-Model?Advice Needed DRB Tile Forum/Advice Board 25 09-30-2010 06:29 AM
Figuring Re-Model - Enclosed Porch to Bedroom/Bath BonesNTX Tile Forum/Advice Board 8 10-10-2008 06:43 AM
Starting a Master Bath complete remodel Shower first Darren Thomas Tile Forum/Advice Board 21 08-09-2008 03:14 PM
Major Master Bath Renovation Complete JayHill Tile Forum/Advice Board 3 03-06-2006 02:50 PM
complete master est. rob 223 Professionals' Hangout 7 08-14-2004 06:58 PM
