Unread 12-30-2020, 12:54 PM   #1
shleprock
Tiling a narrow curb - looking for ideas!
Hi all
I tried to maximize space in my small bath by cutting a KBRS curb in half ..feeling I should have planned this a bit better because I now have a 2" wide curb...2" high inside, 3 1/2" high outside. Pan floor will be same basketweave as bath floor - walls are 3 x 6 white subway. I was initially considering a cultured marble sill/threshold curb top - but the easily available beveled ones are 4" wide..leaving me more overhang that I would like. I'm having trouble finding a relatively simple solution but hoping I'm just not creative enough.
Any ideas? Appreciate the forum's help!
Tony
Anthony
shleprock is offline   Reply With Quote
Unread 12-30-2020, 02:40 PM   #2
Carbidetooth
Hmmmmm
Carbidetooth's Avatar
You could tile over it with bullnose tile. Another option would be to have a piece of stone or quartz cap cut and polished at a fabricator.
Peter
Unread 12-30-2020, 03:40 PM   #3
shleprock
Thanks Peter. I think that might be the most straightforward strategy since there is a matching 2" bullnose for my subway tile. Thanks for laying that out for me.
Anthony
Unread 12-31-2020, 03:59 PM   #4
larrylv
I had a similar narrow curb and simply used the main field tile and had the Schluter profile on the edge (see photo). The inner part of the curb uses the same profile. It all worked well.
Larry
larrylv is offline   Reply With Quote
Unread 12-31-2020, 09:25 PM   #5
HD sells a 2" curb you might be able to use...or, if you have a wet saw, you could cut down a 4" curb...or even possibly use it as is, although with a bit of an overhang.
Were it mine, I would have a granite yard cut down from some scraps, exactly the size you want. Shouldn't be more than 50 or 60 bucks......
(The original Latin seems to have been garbled.......)
Unread 01-01-2021, 08:20 AM   #6
I'd go ahead and tile the inside and outside of the curb and hang the slab over like Laz said. It might be a little over 1/2 inch but won't look bad in my opinion.
Shower Curb Cap too Narrow - HELP! effex80 Tile Forum/Advice Board 4 07-08-2020 08:49 PM
Creating a narrow curb KSDIYer Tile Forum/Advice Board 9 06-24-2012 10:55 AM
Tiling a varying-height shower curb; Penny tile OK on top of curb? smcquaid Tile Forum/Advice Board 6 01-07-2012 09:02 PM
Narrow Shower Curb bmcglothlen Tile Forum/Advice Board 8 01-01-2012 02:52 PM
Narrow Curb Question RubenDog Tile Forum/Advice Board 12 09-23-2008 07:58 AM
