Unread 03-25-2016, 08:48 PM   #20746
Autoplay
Tile Setter
Hopefully weather holds out!
Rich
Autoplay is offline   Reply With Quote
Unread 04-01-2016, 04:25 PM   #20747
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Location: Maple Bay, BC (On beautiful Vancouver Island!)
Send a message via Yahoo to GraniteGirl
Making a niche insert for our shower (it is nice working on our own stuff for a change!)
The stained glass window is the inspiration:
The drawing:
In process:
Almost done - just need a few pinholes filled:
Materials used: Carrara, red onyx, Rain Forest marble
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Unread 04-01-2016, 06:26 PM   #20748
HS345
Tile Contractor
HS345's Avatar
Rich, that could be my jobsite, I've got that same dolly, bucket dolly, and coffee can.
Adriana, holy mackerel, that's awesome.
The name's Greg
Unread 04-01-2016, 08:50 PM   #20749
Beautiful! What's the black stuff, Adriana? It looks too thin to be silicone.
Unread 04-01-2016, 09:38 PM   #20750
nelsonkoehn
showers & more
nelsonkoehn's Avatar
Sweet!
Nelson
tile.nkoehn.com
Unread 04-01-2016, 10:07 PM   #20751
GraniteGirl
Ms. Makita
Your Works In Progress Pics
It is Integra Adhesive - a 2 part glue that has great water resistant properties. We use it to build soapstone sinks. It dries rock hard and can be ground and polished. Comes pre-coloured and is an all round awesome product.
Thanks for the comps, y'all
Adriana
Unread 04-02-2016, 07:25 PM   #20752
Good Morning Flooring
Journeyman
From a short while ago. I am just happy with the cuts around that mantle Wish they let me redo the hearth though, that is original tile, had matching stuff on the wall before.
Edit: Adriana, that looks awesome. I think I may have to try something like that soon
Steven
Last edited by Good Morning Flooring; 04-02-2016 at 07:29 PM. Reason: Where are my pictures?
Good Morning Flooring is offline   Reply With Quote
Unread 04-02-2016, 08:24 PM   #20753
Brad Denny
Tile Contractor Nashville, TN
Brad Denny's Avatar
Tedious mosaic project...
Brad
Brad Denny is offline   Reply With Quote
Unread 04-06-2016, 03:10 PM   #20754
Autoplay
Tile Setter
Shorts finally arrived,kit BS will be here in a week or so.
Grout this tomorrow,then off to another house to WP a wine cellar that will be potentially used later as an elevator.
Rich
Unread 04-06-2016, 10:13 PM   #20755
Rich, I've never pulled with just thinset, always have had some mud in there. I can see that method working on certain conditions where a large trowel just isn't quite enough. When you use this method is the thinset fairly loose and pull with a box screed? Also you said you pulled it one way and wish you'd pull it the other way as well. Are you saying screed it east to west one day then screed it north to south the next?
Unread 04-08-2016, 06:00 PM   #20756
Autoplay
Tile Setter
When I use that method,the thinset is "just right". Make it too loose,it could potentially sink,along with causing bubbling,which you'll see the next day. Too thick,and it's hard to pull,and taking a diceroll on it bonding etc(esp if not burning into concrete as you pulling along).
Wine cellar/elevator shaft WP first coat,spent over an hour prepping,and removing what looked like roofing felt along the perimeter(possibly used in between formboards?) Absolutely hate grinding concrete,and still affecting my sinuses,even after wearing dust mask lol)
Rich
Unread 04-08-2016, 08:05 PM   #20757
Couple pics of current shower
Unread 04-08-2016, 08:07 PM   #20758
Niche
Unread 04-08-2016, 10:01 PM   #20759
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Nice work Rich. If you have to grind concrete invest in one designed to attach to a vacuum and buy a Dust Deputy. They even make cheap vacuums work good. Worth the money.
Some pictures of a project we completed earlier this year.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Unread 04-09-2016, 04:46 AM   #20760
Autoplay
Tile Setter
Awesome layout Issac,with the fulls etc laid around the niche!!
I rarely/never grind concrete,I generally get the peeps that fudged it up,to do it lol. If I did it more than twice a year,for sure I would invest in a dust collector
Nice mudwork Justin. Like the idea of the holes in your feather edges! Sure beats having the helper hold em in a certain place,hoping he doesn't move em,and sliding them off correctly after mud applied lol.
Rich
Noob - questions and (eventually) progress pics hamfist Tile Forum/Advice Board 1 01-29-2011 09:19 AM
Kerdi shower in progress -- 5 pics 4 questions ritch Tile Forum/Advice Board 4 04-20-2009 11:32 PM
Another job finished up (pics) Chris H Tile Forum/Advice Board 10 04-01-2008 06:21 AM
