Unread 10-23-2019, 09:42 AM   #106
If you still have a steel bodied truck, that is.
Unread 10-23-2019, 07:21 PM   #107
CaliGrown
CaliGrown's Avatar
Works on any truck or van as long as you hold it there until it grabs
Christopher Machado
1 (916) 990-1751
Unread 10-23-2019, 07:55 PM   #108
KiwiTiler
Embedded magnets if you have an internal racking system, saves having nails sticking out and catching when the levels ain't in the van..
Mark
Mark
KiwiTiler is offline   Reply With Quote
Unread 03-25-2020, 02:23 PM   #109
Shady at Best
Tyrone shoelaces
Shady at Best's Avatar
My newest hack is using flexible PVC for lining up bath tub drains.
Sent from my SM-G965U1 using Tapatalk
Travis
It's just a clever handle.
Unread 03-25-2020, 02:29 PM   #110
Thought you'd already figured that out on your project thread, Travis.
Unread 03-25-2020, 02:31 PM   #111
Shady at Best
Tyrone shoelaces
I did. I figured I would share with the world
Travis
Unread 04-03-2020, 10:11 AM   #112
kevreh
kevreh's Avatar
Travis,
Where do you get your flex pvc? I used it years ago but can't recall where I got it.
kevreh is offline   Reply With Quote
Unread 04-03-2020, 12:47 PM   #113
Tiger Mountain Tile Inc
So how does this hack work?
James Upton
Unread 04-03-2020, 01:41 PM   #114
Shady at Best
Tyrone shoelaces
I have seen it for sale on line at home depot. Pool and pond supply stores stock it in my area. The hack is to build the tub drain/ overflow out of it. Then use a PVC p trap and if you can use a 12" length off the p trap and connect it to your waste line. In CA we use abs and this connection can be iffy, a lot of you guys use PVC so it will not be an issue.
This helps with lining the drain up perfectly with the tub. In most remodel situations one doesn't have access to the drain once the tub is in place. One might need to remove the tub and realign the drain a half dozen times to make it fit perfectly. The flex pipe limits this. You can be an inch off and there is enough flex to allow alignment without feeling like you are forcing alignment.
I don't know about you all but I don't like forcing a ridgid drain and rubber gasket in a situation where it might take a month to realize the drain leaks.
Sun2Solar 1.5 Inch Diameter x 50 Feet Length Flexible PVC Hose | Flexible Pipe White Schedule 40 PVC | Perfect for Plumbing Filtration Systems https://www.amazon.com/dp/B06W2N4Q1T..._N94HEb2G8KAJK
There is both white and black PVC in this pic
Cx didn't like CV meme.
Travis
Unread 04-03-2020, 05:16 PM   #115
Just In Tile LLC
Just In Tile LLC's Avatar
Travis awesome stuff! Old plumber told me about that stuff when I saw it under a house as the shower drain line. I've used it maybe twice after that once I found out and can save you a ton of headache when needing a little flex.
In my area Lowes sells it as spa flex hose but it's in the plumbing section and solvent welds straight to the PVC fitting which is awesome.
Justin
Unread 04-05-2020, 09:26 AM   #116
Weitekamp Remodeling
Weitekamp Remodeling and Construction
absolutely brilliant idea. Thanks for the tip on what is normally a frustrating process with the overflow.
Jay
Weitekamp Remodeling is offline   Reply With Quote
Unread 04-06-2020, 08:13 AM   #117
kevreh
kevreh's Avatar
Great tip Travis! I could have used that on a recent job where a little flexibility with the overflow would have made things a lot easier.
My tip is to use a (new) toilet brush to clean thinset or grout buckets. They do a good job of getting into the corners.
Unread 04-07-2020, 07:01 PM   #118
Just In Tile LLC
Kevin have you tried a gong brush?
Justin
Unread 04-07-2020, 08:48 PM   #119
smifwal
What's wrong the customer's? Most of the time it is right there! Unless you were working on a back splash or anywhere else in the house, then that might be awkward
Unread 04-12-2020, 07:55 AM   #120
smifwal
How I store my spacers. Go to the store and buy your own Tupperware. If you take them from the cupboards you wife will surely notice and be none to happy with you. Ask me how I know.
Also these bolts are awesome
making and tiling a half column bender123 Tile Forum/Advice Board 9 06-10-2010 09:52 AM
Another Hack Job HS345 Professionals' Hangout 35 02-24-2009 10:26 PM
An easier way! mmoore Tile Forum/Advice Board 22 12-11-2008 09:07 AM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
