Unread 08-04-2019, 05:24 AM   #91
Karls tile Inc
Tile and stone contractor Tile setter
I will sometimes template the backsplash. Then layout all the tile on the floor and overlay the template. Precut the whole backsplash and then install it.
Karl
Karlstile.com
Karls tile Inc is offline   Reply With Quote
Unread 08-04-2019, 12:41 PM   #92
Karl, what do you make the template out of?
Unread 08-04-2019, 06:45 PM   #93
Karls tile Inc
Strips of luan plywood about 1/4 thick hot glue them together. Pretty much like how counter top guys template. I have also used large pieces of cardboard.
Karl
Karlstile.com
Unread 08-04-2019, 07:28 PM   #94
I was thinking you might use 1/4 inch luan and hot glue.
Unread 08-04-2019, 08:41 PM   #95
CaliGrown
CaliGrown's Avatar
Mixer tips
One handed mixing or free-handed if you have the button lock and can move your hips to dance with the mixer. And a nice spot for mixer storage under the saw. DeWalt didn’t pay me, I paid them a while back.
Christopher Machado
1 (916) 990-1751
Unread 08-10-2019, 10:31 AM   #96
Tiger Mountain Tile Inc
One-handed mixing is important these days because it allows you to hold a camera in the other hand.
I like the storage idea. I usually hang my trowels on the cross bar going the other direction
James Upton
Unread 08-18-2019, 10:23 AM   #97
CaliGrown
CaliGrown's Avatar
Haha. Thanks now all my trowels have a home outside of the bucket bin. Here’s a simple, “niche wedge” I do the same for accent band spacers.
Christopher Machado
1 (916) 990-1751
Unread 08-18-2019, 12:58 PM   #98
smifwal
like this
Unread 08-18-2019, 02:45 PM   #99
CaliGrown
CaliGrown's Avatar
Yep ‘xactly like that. Best way
Christopher Machado
1 (916) 990-1751
Unread 08-19-2019, 12:10 PM   #100
Canvasback Construction
Small tip that I've worked out but it's saved me a ton of headache-I cut aluminum Schluter trim with a Dremel Ultrasaw, it works great but can leave a line of aluminum flashing sticking up from the cut. I used to use some sandpaper to rub it off but you always risk scratching the trim, I hit on the idea of using the back of a tile offcut to rub the cut line, it works like a charm to remove the cutting flash and unless you really get after it it won't scratch the trim. It's been a real time saver!
Cody
Canvasback Construction is offline   Reply With Quote
Unread 09-03-2019, 11:11 PM   #101
CaliGrown
CaliGrown's Avatar
Night time or early morning tile cuts.
Christopher Machado
1 (916) 990-1751
Unread 09-28-2019, 06:10 PM   #102
smifwal
I taught this to a tile guy years ago. I thought it might help someone here.
Whenever putting carpet back to tile. If you are using a kicker make relief cuts before you kick it up on the tackstrip. If you have a power stretcher ( you might already know this) you can make the relief after you make the stretches before you trim the carpet
This is the what I got when I tried to up load the photos
Unread 09-28-2019, 08:31 PM   #103
smifwal
Went back and tried again all is well
Unread 10-06-2019, 02:57 PM   #104
Sdtile
I use a carwash ringer for my grout sponges. Fast, easy and just the right amount of moisture in the sponge.
Justin
Sdtile is offline   Reply With Quote
Unread 10-23-2019, 09:35 AM   #105
CaliGrown
CaliGrown's Avatar
Level storage, magnetic levels aren’t as dumb as I thought.
Christopher Machado
1 (916) 990-1751
making and tiling a half column bender123 Tile Forum/Advice Board 9 06-10-2010 09:52 AM
Another Hack Job HS345 Professionals' Hangout 35 02-24-2009 10:26 PM
An easier way! mmoore Tile Forum/Advice Board 22 12-11-2008 09:07 AM
What a hack job. muley Professionals' Hangout 13 03-07-2007 01:06 PM
Hack job Northwest Tile Guy Professionals' Hangout 19 12-09-2006 06:57 PM
