Unread 03-24-2020, 11:36 AM   #1
scooterCO
stuck: old concrete shower pan (on wood?)
currently remodeling entire shower.
do I remove this existing concrete pan, or can I use it and salvage the sides with new concrete? (for purposes of laying thin-set and tile..)
this pan has a steep slope to the drain, has a rough surface area, and is old.
The question is can I still salvage this pan? Or does it make more sense to jackhammer it out?... it appears to be laid on wood but Im not 100% sure this is my first time doing anything like this. some signs of moisture around some of the wood framing :/
Thank you and kind regards in advance! I am very stuck right now.
scott
scooterCO is offline   Reply With Quote
Unread 03-24-2020, 12:24 PM   #2
Welcome, Scott.
The only thing surprising about your rotting floor is that it's not much worse. The problem with your shower receptor is that you apparently have no waterproofing at all. Poured concrete (what you appear to have) around an inappropriate type of floor drain does not make a waterproof shower receptor.
I would recommend you remove what you have and begin the new shower with at least a properly repaired floor.
Several methods available for building the new receptor and you'll need to chose one before you advance beyond the new subfloor.
Unread 03-25-2020, 12:28 PM   #3
scooterCO
Smile
thanks so much for the direction! will probably rent a jackhammer and get that concrete out. will let you know how it goes
kind regards,
scott
scott
Shower project: stuck! Fresmom Tile Forum/Advice Board 2 05-28-2013 11:57 PM
Stuck set screw on moen shower....help! 4my3kids Tile Forum/Advice Board 19 02-13-2013 07:55 AM
Kinda stuck on shower tub wall ihscout54 Tile Forum/Advice Board 13 08-07-2010 08:41 PM
shower drain stuck nancy24 Tile Forum/Advice Board 15 02-03-2007 07:13 AM
Stuck in the middle of a shower stall BruceC Tile Forum/Advice Board 8 09-23-2003 06:00 AM
