07-02-2009, 05:52 PM
JB
marble mosaic problem...help !
High-End custom home where we just installed 7/16" x 7/16" mosaic tile floor in a guest suite. Sunlight comes into the room from an angle which really emphasizes even the slightest amount of lippage and the butt seams between the sheeted 12x12 mosaic tiles. Were left scratching our heads as to what to do to resolve the problem without ripping it all out and trying again. In order to get proper thinset coverage we trowel the floor and backbutter the tile and slowly & carefully set the tile with our levels, look and feel for any lippage and move on to the next tile. But no matter how careful we are we do get some very minor lippage and as I said earlier when you step back and look at the installed mosaic tiles from a distance of 10-15' you can see where a lot of the tiles butt up to one another. The thin layer of dust that sits atop the tile just seems to make things stand out even more. These visible butt seams seem to be a bigger issue to the designer than any minor lippage but were at a loss as to how to eliminate the problem with this type of mosaic tile. Damn frustrating because we think the floor looks teriffic, not perfect but really well done in our opinion.
This is a good client / contractor of ours and want to come up with a solution but were at a loss as to how we can resolve the problem in an equitable manner for us and the customer. Should we consider sanding/honing the top of the tiles to all but eliminate the lippage & butt seams?
Will this even work ?
We welcome your input, tips / tricks and possible solutions as this is a new one on us and the designer is of course being somewhat anal in our opinion but the contractor wants to keep her happy, so were willing to do what we need to do to keep everyone happy.
Thank You in advance ...
Jerry
07-02-2009, 06:15 PM
Tile contractor
Jerry
I saw your post this morning, You really shouldn't be able to see a height difference where mosaic sheets meet. Doesn't sound right. How much lippage? The floor can be ground in but you're gonna need a pro to do it. I've never had a pro do it for me, thats how I know you need a pro to do it
Maybe someone from your area will stop by and point you in the right direction with a contact.
Matt
07-02-2009, 06:21 PM
You can indeed polish the tiles in place. I have no clue how as I've never seen it done, but it can be done. Im sure someone with more experience will be along shortly. In the mean time you could head over to the works in progress thread as I believe there are some pics there.
http://www.johnbridge.com/vbulletin/...=70412&page=68
Post 1012
I'm Dan.
I am the master of my fate:
I am the captain of my soul.
-"Invictus" by William Ernest Henley
07-02-2009, 06:28 PM
Hugging Trees Oct. 1st
I think Jerry is saying his mosaics are on the sheets butted together in places.
I can see in my head what you are saying and I would recommend the palm sander. I would make a sample board to come up with a plan for the grits and the finished hone but I'm sure it can be done.
Jason
07-02-2009, 07:34 PM
Hire new member stone dude.
Sorry to hear of your "problem"
Sheer drapes to diffuse light coming thru the window?
gueuze
07-02-2009, 10:13 PM
Hi Jerry,
Sometimes the "factory spacing" on sheet mounted mosaics doesn't cut it. I usually keep a razor handy while setting, and will stick the blade through the grout joint and cut the mesh where needed to adjust the spacing. Yes, its a pain  On some materials/patterns/etc you notice it a lot, others its not as big a problem.
Hope you get this worked out to everyones satisfaction.
Brannigan
HeenanGC.com
07-03-2009, 05:22 AM
Tile & Stone
Did you inspect the material before install. We had some mosaics from Akdo that had to be some of the worst material I have ever seen. 1/8" difference in thickness from sheet to sheet, and on the sheet. Akdo used to have nice material but they went big time into high end and it is mostly overpriced landfill that they sell now. What exactly is the material you installed?
CTEF Certified Installer
07-03-2009, 06:49 AM
what about using the Tuscan Leveling System?
07-05-2009, 11:42 AM
JB
I've heard the Tuscan leveling system is intended for 12 x 12 and larger format tilework...
07-05-2009, 11:47 AM
JB
Well I think by the reply's we will try to wetsand with a palm sander a small area repolish as necessary and see if it resolves the problem and take it from there.
Thank's guys I appreciate the input
07-05-2009, 12:12 PM
Deckert said it best about how to eliminate where the tiles look like they don't fit preoperly. I always keep my Olfa blade handy to cut the mesh like he said and adjust til they are square with a uniform grout joint everywhere. Doing tons of mosaic myself, I found that using a floor tile (12x12 or larger) to press down on the sheets (flipped over so the face of the tile is against the face of the mosaic) works great to eliminate lippage on walls and floors. It works better than your level because it's a larger surface area. I usually keep a spare tile in the back of my truck just for these situations...
Are the tiles grouted yet? Natural light can accentuate even allowable lippage in ungrouted floor tile (1/32-1/16) to the point where it looks really bad because of the shadows cast....Once it's grouted the look usually goes away.....
-JW
07-07-2009, 04:11 PM
how about a pic
just to establish how bad it really is?
I don't know how you eliminate the butt seams except to stagger the sheets?
as far as the lippage, you could fresh set the material and beat it in to flat?
I'm not comfortable with the hand sander idea . . .
a large floor polisher would be better I think -- saw a recent post where
a trav floor was polished out and it looked great
that said, mosaics would be very challenging for anyone to resurface -- seems like the edges would catch on the diamond disks.
still, if the cost pencils out vs a redo , it's worth a shot.
good luck
Stephen -- Man vs. Tile -- The Battle Continues . . .
