my rep told me that there is an epoxy mix available for hydroment grout. anyone ever use it?
Yep Both Kinds...1900 & their 100% Solids
Ive Used Hydroment for YEARS..
YES they have BOTH modified and NON Modified
Here is the DIFFERENCE If you use a NON Modified grout.
DAMP CURING!!!!
All things being equal if your structure can handle a ceramic installation, Modified is NOT necessary.........You can use a NON Modified but you should damp cure the grout for 5-7 days for best Strength least porosity etc.
Vary rarely will you see a Modified grout used on an Interior Commercial Floor, particularly if its Slab On Grade.
In Fact, Chances are its probobly a 2:1 sand/cement mix used to make natural grout.......Sometimes Brick Mud colorant is added but Latex?? NO WAY!!!
Walk around a Mall thats tiled......Look for Grout problems..........If the job was done properly ( and most in our area were Union crews from Grazzinni or Milw tile & Terrazzo Or Detroit Tile) Chances are you will not find any problems and I can about gaurantee no Latex was used.
Latex is an Expedience thing.........Keeps grout from shrinking during a dry cure.
Great product if you want to grout and walk away.....BUT, its never been a neccessity, more of a convenience
Adds Elasticity to the grout??? - Once its cured, if you need Elasticity, you probobly needed MORE Support!!!
How Much
Elasticity is a Cured cement product REALLY going to gain from a latex addative.....Think About it!!
TILE SHOPS Cleans up EZ for 2 reasons...High Glaze tile like you mentioned, But also A VERY HIGH Water Content.
Theres just not alot of Latex in their Admix
