1.) I wouldn't call RedGard standard procedure. It's just one way of doing it. You can use poly sheets or roofing felt behind the CBU. The important thing is to pick one AND ONLY one barrier and go with it. Two barriers is asking for trouble in the form of a moisture sandwich.
2.) Silicone caulk will not provide the structural support of taping the joints with alkali resistant mesh. Silicone is good for waterproofing, but CBU isn't waterproof to begin with. CBU is not damaged by water, but it does not serve as a water barrier. To avoid the "speed bumps", just put the mesh on as you are setting your tiles. I've been doing this and it works just fine.
Dan - a DIYer in SE Tennessee
