Hi, great site. We are starting a bathroom remodel in a few weeks, and we have some questions. We've done four or five tiling projects before, but never in a really wet environment. I checked the Deflecto and we're fine for ceramic tile. We're ripping out the old tub and tile and replacing it with a 34x60 shower. We're planning on using solid surface pan, then 1/2" cbu on the walls (taped and mudded), Redgard, then tile. On the floor in front of the shower and around the toilet, I was planning on using 1/4" cbu and Redgard. I like the idea of Ditra (who wants to carry cbu up a few flights?), but we already know how to use cbu, and we don't like a lot of learning curves.
Will the Redgard on the floor do the trick to waterproof it? My biggest concern is the area where the floor meets the pan, since the pan will sit directly on the plywood subfloor. We are also going to build in some niches on the back and side walls. Is there any difference in performance between Redgard and felt/plastic in this instance. We will have four small body sprays on the front wall, in addition to the shower head. Also, any pointers for ensuring the drain doesn't leak?
I know you guys like tiled floors, and I do to. However, we seem to have bad luck with contractors (even I know water can't drain uphill!)
, and since we will do the walls ourselves, I'm afraid that any leaks that develop will be passed off as the fault of our tiling job on the walls. We like in Washington D.C., so I don't think the cost of the solid surface pan (400-600) is going to be more than having a mud floor made.
Any suggestions will be greatly appreciated! Thanks, Cheryl
