First post so I hope I get this "right."
Background
I'm redoing my master bath (L-shaped 56 sqft, 3x3 shower) and to this point, I have ripped out everything down to the joists. I have attempted to level the floor via glued and screwed 2x6's as mentioned throughout the forum. I have blocked in 2x4s to supported otherwise unsupported edges and topped it all with 3/4" Advantech subfloor (heavy stuff by the way!)
My joists are 2x9 (true 2" width), 16" OC, 13' in length, unkown wood (house built in 1975) = L436 deflecto score.
I plan to put down Ditra and 12"x24" porcelain tile (that my wife likes it)
Question(s):
1. I feel like there may be some wave or slight unevenness in the floor and I know its not flat/level nor am I going to try and level it...just trying to achieve flat.
a. Will adding another layer of 1/2 plywood help even out the "wave" or if I'm screwing every 8 inches in the field will that only amplify any issues?
b. If there are any valleys, can I fill them with Ardex Wood or Henry FeatherFinish patch compound first?
2. The old sub floor was 1/2 plywood with a mortar bed on top. Due to wall and joist placement, I could not cut 2" of the exposed 1/2" subfloor out along one of the walls. Should I lay in another 1/4" x 1.5" strip to fill the void before putting underlayment on top over everything?
3. This is my first time putting down floor tile. Have I dug my own grave by attempting such a large format tile?
I'm sure I'll think of more questions but will tack those on later if I do.
Thank you in advance for not beating up the newbie.
