Unread 09-24-2009, 03:22 PM   #1
masonry question
Doing some block work for a friend and some parging of the block. I was going to use type S cement to mix with bar sand i think it comes in an 80 lb bag and its both lime and cement does anyone know how much sand to add I read somewhere 8 parts but this seems a bit high to me. Also does anyone know how to make the scalloped effect with a flat trowel to make a stucco finish? I have no problem throwing up the scratch coat but the finished coat with a ripple effect if I can. Or I was thinking of troweling it smooth and hitting it with a wooden float to finish the top coat.
Unread 09-24-2009, 03:45 PM   #2
custombuilt
don't know on the stucco effect but when I lived in Peru we used to smooth parge brick and block with 1 to 3 portland to fine sand mix. We gaged the walls with straight edges and then troweled them smooth with wood float.
Also we wetted them down first too.
Jason W.
Superior Construction
Quincy, IL
Unread 09-24-2009, 04:09 PM   #3
Rd Tile
Tile Man
Rd Tile's Avatar
Scalloped effect, get the right amount of mortar on a trowel [practice] place it against the wall, work upwards turning the trowel outwards leaving it thicker at the top.
Richie.
Masonry question. Painted brick issues. scarywoody Tile Forum/Advice Board 4 03-03-2007 04:09 PM
Masonry question Tool Guy - Kg Professionals' Hangout 4 09-03-2005 12:38 PM
masonry pricing madmangil Professionals' Hangout 17 05-11-2004 06:11 PM
Masonry LadyGodiva The Mud Box 27 05-11-2004 11:31 AM
Need Masonry Direction... Dave Anderson Tile Forum/Advice Board 17 03-10-2004 05:10 PM
