Unread 06-06-2020, 11:10 AM   #1
DaveYoung
Transition piece/ Sliver tile cut
So I miscalculated my final door piece and somehow will end up with a 3/4" gap when I thought I would be cutting 3/4 off. Its 1" to the hardwood. The tile is about a 1/2" higher and I was gonna use a reducer transition piece regardless.
I don't mind a sliver by the door but would it make more sense to cut out the hardwood to put a bigger piece? I could potentially slope it even since half would be off the uncoupling layer.
Thoughts are appreciated, thanks!
See attachment
Edit: Also while I did cut the door jam, I could glue the pieces back. Is this 1 inch gap still perfect for a reducer transition piece. Is that something custom out of wood or would a big box store have it
DaveYoung is offline   Reply With Quote
Unread 06-06-2020, 02:48 PM   #2
Lazarus
Lazarus's Avatar
I think a "T" molding or a reducer would work out well....
Laz...
Unread 06-06-2020, 04:03 PM   #3
I wouldn't install a tile sliver. I'd make the wood reducer span the whole space.
Unread 06-06-2020, 06:20 PM   #4
DaveYoung
Perfect! Thanks guys, that makes me feel alot better
Unread 06-09-2020, 06:05 PM   #5
DaveYoung
I've tiled the floor with a large format tile modified thinset and the redguard uncoupling layer (which promotes using modified thinset I beileve).
I have some messy joints that I would like the clean up and it will be 84 hours by tomorrow morning since the last tile was laid. I realize its probably way harder to clean stuff now but is 84 hours enough to be able to walk on the tile? I want the highest chance of success and to avoid tile failure so I can easily wait a week if needed. Research had varied results. Any thoughts?
Edit : 1/2 mortar and 6x24 tiles
Unread 06-10-2020, 07:06 AM   #6
You'll be able to dance on it by now, Dave.
Unread 06-10-2020, 09:52 AM   #7
DaveYoung
Perfect thank you !
Tile Sliver Advice Fift7Lefty Tile Forum/Advice Board 2 05-26-2016 04:52 PM
The tile sliver OneStaple Tile Forum/Advice Board 3 12-27-2013 06:36 AM
need 2 and a half inch transition piece! thomasamiller Tile Forum/Advice Board 2 02-14-2007 05:11 PM
transition piece tyl Tile Forum/Advice Board 1 07-01-2006 12:44 AM
Slate tiles and transition piece jarbaugh Tile Forum/Advice Board 1 12-05-2005 10:38 PM
