Unread 05-06-2020, 12:39 PM   #1
Hamerhead
Sanded grout cleaner porcelain tile
What is the best cleaner to use for refreshing the grout lines on my 16 x 16 porcelain floor tiles. It was sealed after installation about 8 years ago, but has gotten quite dark looking over time. I'm not opposed to manual labor, (if necessary), so scrubbing with a brush on hands and knees is an option, but I want it to look virtually new when done. Looking for the best cleaner?
Paul
Hamerhead is offline   Reply With Quote
Unread 05-06-2020, 01:03 PM   #2
Hi Paul,
I don't think you'll find a cleaner that will make the sanded grout joints look like new after 8 years. It's just now going to happen. You can try steam cleaning or a grout colorant.
Unread 05-07-2020, 04:46 PM   #3
A recent This olde house show used a mix of baking soda and vinegar applied with a toothbrush...at least in their situation, it cleaned up the grout. Rinse well. The foaming action along with the vinegar seemed to work. This was a fairly light colored grout, and at least on the screen shot, it looked quite a bit brighter when they were done. There are grout cleaners you can buy...don't have any experience with them.
Unread 05-10-2020, 09:03 AM   #4
I keep a bottle of Krud Kutter in my truck along with a drill brush (Amazon). It's a good cleaner and is even safe for stone. Like John said, I doubt anything will make the grout look new.
Spray on the cleaner and let dwell. This is important. Scrub with a brush and pick up with a shop vac. Rinse it with clean water and pick up again with vac. I also have a brush that has a handle on it, that way I can stand up when scrubbing.
I've also heard the vinegar/baking soda mix works but have never used it. Even if you plan to use a colorant, I'd first clean the tile and grout well.
Unread 05-10-2020, 09:33 AM   #5
jerrymlr1
I have used a mix of Soft Scrub, Dawn, and Borax with tooth brush and micro fiber rags for years. We have horses and dirty feet make it thru the door no matter how hard we try to clean them.
Jerry
Porcelain in shower with sanded grout NCTilenoob Cleaning, Restoration and Sealing 3 11-10-2010 09:49 AM
Can sanded grout scratch glazed porcelain? polancho Tile Forum/Advice Board 3 05-10-2010 03:53 PM
polished porcelain/sanded grout lyndaz Cleaning, Restoration and Sealing 2 02-03-2007 08:14 AM
Best sealer for Porcelain Tile and Sanded Grout brians Cleaning, Restoration and Sealing 3 04-19-2006 08:21 PM
Sealing sanded grout, porcelain tile Deirdre Tile Forum/Advice Board 53 11-11-2002 06:20 PM
