Unread 04-27-2020, 05:58 PM   #1
Jax2000
Green board question
Hi, I can’t find much information anywhere for using green board. My question is can I use green board for my kitchen backsplash? I’m wanting to rip out my glass tile and the drywall, and install green board and then put the mother of pearl tile on it. I’ve use the mother of pearl tile before so I’m familiar with working with that. I would like to know the process of using green board, if I need to prime it, do I mud and tape the joints just like I would regular drywall? Thanks!
Jax
Jax2000 is offline   Reply With Quote
Unread 04-27-2020, 06:18 PM   #2
I would use green board only for lining the bottom of a dumpster. Outside of that, it's not useful for much.
For tile in a dry area, such as a kitchen backsplash, I'd use plain white sheetrock. Use alkali-resistant mesh tape and mortar over any seams, and tile directly to the sheetrock.
I'd use a white, modified mortar for the tape and mud, and for setting the tile.
Unread 04-27-2020, 09:37 PM   #3
Welcome, Jax.
I have no eye-dee why Kevin wants to line the bottom of his dumpster, but I agree it's an appropriate use of MR Board. Maybe it's an Arkansas thing?
Unread 04-27-2020, 11:08 PM   #4
Cause if I had me some green board, and a dumpster, that's all I could do with it!
Plus, if it ended up on top of the dumpster, some other contractor might see it, and laugh at me.
Unread 04-28-2020, 06:41 AM   #5
smifwal
Originally Posted by kman
. other contractor might see it, and laugh at me
well that's not true, more likely some other contractor would scoop it up for his next project, a backsplash, perhaps
Unread 04-28-2020, 12:04 PM   #6
Redlands Okie
Those are the guys that keep some of us in business. They cannot do its right the first time so it allows some of us to do it right the second time
Would be nice to get the job to start with. Save the hassle and expense.
Robert
Redlands Okie is online now   Reply With Quote
Unread 04-28-2020, 12:34 PM   #7
I guess I should have said, "some self-respecting contractor.
Unread 04-28-2020, 06:46 PM   #8
Jax2000
Ok guys, thAt seems to be the consensus. I will use drywall Sheetrock then. Thank you for your advice! But why not the green board, supposed to be water and mildew resistant, I know it’s not proof. But with that said it seems a step above drywall ????*??
Jax
Unread 04-28-2020, 07:32 PM   #9
smifwal
It is all the things you mentioned, but it doesn't play well with thinset. Thinset bonds better to regular drywall vs the waxy film that makes up green board
Unread 04-28-2020, 09:24 PM   #10
I agree with Shawn. The scant advantage of having a microscopically small amount of water resistace is far eclipsed by the disadvantage of being more difficult for adhesives and paint to bond to.
Even if green board was free, it would never come onto my job site unless required by code.
Unread 04-29-2020, 01:59 PM   #11
Jax2000
Thank you for your replies! Didn’t know how disliked green board was! It makes sense after what you guys said about it. Guess it won’t make its way in my house either then! Appreciate your help
Jax
Unread 04-29-2020, 05:06 PM   #12
Jax2000
Non sanded white epoxy grout
So I’m about to start our tile project in a few days, but I cannot find a non-sanded white Epoxy grout for the mother of Pearl mosaic backsplash, that’s going in the kitchen . I really need a stain proof or super stain resistant grout because everything is white. Do you guys have any suggestions? Thank you!
Jax
Unread 04-29-2020, 05:40 PM   #13
I would call Laticrete and ask them if it's okay to mix Specktralock part A and part B and add unsanded white grout to it.
Spectralock can be used in 1/16 joints. How wide are yours?
Unread 04-29-2020, 05:59 PM   #14
This might be what you want https://laticrete.com/en/tile-and-st...nslucent-grout
If you wanted, you could add their Dazzle to it which would add glow in the dark and small metallic sparkle.
Unread 04-29-2020, 06:59 PM   #15
Jax2000
Grout joint is 1/8 in. Maybe I should call them. I’m not sure about a translucent grout. I don’t even know if I’ve ever seen what a translucent grout looks like. But thank you!
Jax
Green board? Cement board? Kerdi board? cburrows84 Tile Forum/Advice Board 7 03-21-2014 11:44 AM
shower rebuild - need help with backer board & green board johndoe12345 Tile Forum/Advice Board 9 11-28-2011 10:50 AM
Standard Sheetrock, Green board, or Cement Board skengum@hotmail Tile Forum/Advice Board 5 09-07-2008 06:34 PM
joint btwn cement board/green board tilingisfun Tile Forum/Advice Board 8 01-11-2006 06:38 PM
green board question-a little off topic macska Tile Forum/Advice Board 5 04-24-2005 05:52 PM
