Unread 07-28-2017, 06:59 PM   #1
Sandy06230
T&G Sub-Floor Question
Hi,
I would like to tile my bathroom but not sure if it's advisable due to the joist span and sub-flooring. The bathroom was added on in the 1950's (2x6 joists, 16 OC...I believe it's douglas fir but not certain). The sub-floor is tongue & groove (installed perpendicular to the joists) and in some places it looks like the gaps between boards extend beyond the groove so that it looks like regular plank flooring. The bathroom dimensions are 11'6" x 9'6" and the porcelain tile I'd like to use is 18x18. Adding a support wall isn't an option since the boiler and water pump take up most of the room under the bathroom. My question is, if I add 3/4" plywood over the existing tongue & groove sub-floor, would that lessen the deflection to a point where I can tile?
Sandra
Sandra
Sandy06230 is offline   Reply With Quote
Unread 07-28-2017, 09:16 PM   #2
Welcome back, Sandra.
Can't even get started without we know the unsupported span of those joists.
Tile industry standards require a minimum of 1/2" plywood over your sawn board subfloor, but I think more is better when you don't have a T&G subfloor to start with.
Is a support beam an option?
Unread 07-29-2017, 05:51 AM   #3
Sandy06230
The walls are supported by foundation on all four sides. The majority of the house is built over a dirt crawl space so under the bathroom is the only place for the boiler, water pump, water softener, plumbing...it's very congested so I would think the time and cost to put in a support beam or sister the joints may be cost prohibited. I'm just wondering if 3/4" plywood would stiffen the sub-floor it to a point where I wouldn't risk cracking the 18x18 tile or if I should seriously consider some other type of flooring (i.e. vinyl, wood) or use a smaller tile.
Sandra
Unread 07-29-2017, 09:07 AM   #4
Nothing you install on top of your existing subfloor will improve the design deflection of your joist system.
And again, we don't know the unsupported span of your joists.
A different type of floor covering may be your only reasonable option, but we don't know that.
Unread 07-29-2017, 10:24 AM   #5
Sandy06230
The unsupported span of the joists would be the dimension of the bathroom since I didn't measure in the basement but in the bathroom only. Hopefully I understood your question correctly.
Sandra
Sandra
Unread 07-29-2017, 11:34 AM   #6
The unsupported span is the distance that the joists run without any support from underneath. Unless there are supports under the bathroom walls at both ends, then that's not the unsupported span.
Unread 07-30-2017, 11:24 AM   #7
Sandy06230
Thanks Kevin for clarifying. I measured from the basement to determine the unsupported joist span (2x6)...it's 9 feet.
Sandra
Unread 06-25-2019, 07:53 AM   #8
Sandy06230
Rectified Tile in Shower
Hi,
We're planning another tile project in a bathroom (tub surround). We noticed that a Big Box store carries Anatolia polished porcelain tile (12x24 rectified) as a special order. I'd like to have very thin grout lines (1/16" or 1/8"). Does anyone have experience with Anatolia tile purchased from Big Box store? If yes, should I be concerned with the quality/variation of the tile especially since we want such thin grout lines?
Also, can we use epoxy grout when grout lines are so thin?
Thanks in advance!
Sandra
Unread 06-25-2019, 09:36 AM   #9
Do tell if you tiled the bathroom floor with those inadequate joists and how it's holding up.
To evaluate those tiles (I'm not familiar with the Anatolia brand) the first thing you want to know is whether the manufacturer indicates they meet the ANSI A137.1 standards. Without that, the only thing you have to guide you is their advertising, which may or may not tell you accurately what to expect.
I would also caution you that there is a known problem with grout permanently staining polished porcelain tiles. I do not know if that problem extends to epoxy grouts, but I would want to know before deciding on my tile and grout.
Unread 06-25-2019, 10:03 AM   #10
Sandy06230
No Tile in Bathroom
Thanks for reminding me...I did take your advice as I value and appreciate everyone's experience/knowledge on the forum. We decided to put hardwood flooring, quarter sawn oak, since it's more stable than plain sawn oak (less expansion & contraction) and put 3 coats of commercial grade sealer. It's a bathroom not used often....looks great.
Sandra
Unread 08-03-2019, 05:43 AM   #11
Sandy06230
Thanks CX for the tile advice regarding the polished tiles. We used Roca brand on previous projects (not polished) and got very good results with epoxy grout so I'll stick with the same brand.
Thanks again...Sandra
Sandra
Unread 05-31-2020, 04:28 PM   #12
Sandy06230
Durock Edgeguard
Does anyone know if the Edgeguard on Durock is supposed to be removed before tiling? I ask because the Edgeguard is loose/unattached in several places and we're getting ready to tile a tub surround. The last time we tiled, Edgeguard wasn't available at that time.
Sandra
Sandra
Unread 05-31-2020, 05:12 PM   #13
Not sure without a photo just what you're experiencing, but there is nothing that should be removed from Durock before using except for pieces cut off to make it fit your space.
Second Floor Bay Window Question, Cantilevered Floor Structure pvco Tile Forum/Advice Board 1 05-06-2015 12:08 PM
Sub Floor Question gjfilzen Tile Forum/Advice Board 2 10-13-2013 09:18 PM
Shower Question And Slate Floor Question MICORING Tile Forum/Advice Board 6 11-20-2008 10:27 AM
Sub floor question ... Randy B Tile Forum/Advice Board 5 05-11-2005 02:21 PM
Question on sub-floor Wish Me Luck Tile Forum/Advice Board 5 06-22-2004 12:19 PM
