Unread 07-23-2018, 11:51 AM   #1
Mathman
Small row of tiles outside front door.
I replaced my front entry door and had to remove a row of tiles at the threshold.
I want to put them back rather than replace the entryway tiles but I don't have any thinnest mortar. Just a container of Mastic I used for the backsplash. It says not for exterior but do you think it would hold that small row. The door rarely gets wet except in hurricane force blowing rain.
Am I wasting my time and it will come up as soon as it gets wet?
pics.
Kirk
Mathman is offline   Reply With Quote
Unread 07-23-2018, 05:04 PM   #2
Hi Kirk. No way would I use mastic for that. Get some thinset. And, not the 6 dollar stuff and not premixed. Also, it's a good idea to caulk the joint against the threshold.
Unread 07-23-2018, 06:20 PM   #3
tatumjonj
Listen to the pros. No way that should be used for anything, let alone outside on a walkway even if you don't really walk on it.
Jon
Unread 07-23-2018, 06:46 PM   #4
Mathman
Ok. Don't try to save 10 dollars on a $1300 door. That is what I am hearing. A life of fixing everything with duct tape and bailing wire will do that to you. Even as I resist...
Kirk
Unread 06-04-2020, 08:15 PM   #5
akakk
I have always mixed my thinset, but what is wrong with pre-mixed for a small job? just wondering what it lacks. thanks
Karen
akakk is offline   Reply With Quote
Unread 06-04-2020, 09:57 PM   #6
Karen, rather than confuse an old thread, you'll do much better if you ask that question on your own project thread where we have the proper context to work with.
Tiling in front of a sliding door... FHStudios Tile Forum/Advice Board 2 01-12-2009 01:25 PM
tiling area beneath door jamb on front door jepthng Tile Forum/Advice Board 1 09-24-2006 03:27 PM
buying a front door Johnnymac96 Professionals' Hangout 7 11-17-2005 06:05 PM
grout joint in front of door? bunt Tile Forum/Advice Board 5 05-05-2004 07:20 AM
Front door placement Jason346 Tile Forum/Advice Board 2 11-22-2003 08:10 PM
