Unread 04-30-2020, 04:56 PM   #16
Spectralock also comes in an opaque version. https://cdn.laticrete.com/~/media/au...DC51D70B51B8DE
Unread 04-30-2020, 05:45 PM   #17
I'd use regular Specktralock. The grit is finer than most sanded grouts.
Unread 04-30-2020, 06:24 PM   #18
My thoughts were that the tile you're planning is sort of iridescent, and the first one I mentioned would seem to complement that. A solid white might not. Haven't done it, so can't tell for sure.
Unread 05-01-2020, 08:29 PM   #19
Jax2000
So the mother of Pearl does have an iridescent quality to it, however I like your thought of an opaque version better. Is the opaque version also unsanded?
Jax
Jax2000 is offline   Reply With Quote
Unread 05-01-2020, 08:50 PM   #20
The spec sheet says it can be worked into 1/16" grout joints...the sand in it is quite fine and I think you'll find that it is rounded rather than sharp. You could call them to get their thoughts on it...
Most of these epoxy grouts come with three packets:
- accelerator
- epoxy
- colorant, that may be sort of like sand, but may be plastic - they call it a powder in the instructions
Depending on what you're doing, you have some flexibility on how much of the part C, or colorant you use.
Last edited by jadnashua; 05-02-2020 at 03:33 PM. Reason: added more detail on components
Unread 05-02-2020, 05:41 PM   #21
Jax2000
Thank you Jim!
Jax
Unread 05-04-2020, 06:36 PM   #22
Jax2000
Great, that means I can skip the priming! Thank you guys a ton!
Jax
Unread 06-01-2020, 06:35 AM   #23
Jax2000
Btw, we’re finally just starting and I got the materials but wondering if using regular drywall screws is acceptable? Or do I need special screws for the Sheetrock? I did get the alkali resistant tape as recommended. Thank you!
Jax
Unread 06-01-2020, 09:04 AM   #24
The regular DW screws will be fine Jax.
Unread 06-01-2020, 10:07 PM   #25
Redlands Okie
Have fun with the project.
Robert
Redlands Okie is offline   Reply With Quote
Unread 06-02-2020, 01:52 PM   #26
Jax2000
Thank you ! So just to make sure, tape seams with alkali resistant tape and use white mortar. To prime or not to prime drywall?
Jax
Unread 06-02-2020, 02:00 PM   #27
You don't need to prime the drywall prior to tiling. You do not want to use drywall mud on the seams, but do tape the seams. You may want to do that as you tile the area, as if you do it beforehand, you may end up with some speed bumps.
Unread 06-02-2020, 11:55 PM   #28
Jax2000
Good idea, I thought I would tape with mortar and sand the seams if I needed too. But if I can tape and install at same time,, even better! Thank you Jim!
Jax
Unread 06-03-2020, 10:00 AM   #29
Welcome, Jax.
It'll help if you'll keep all your project questions on one thread so folks can see what you're working on and what's been previously asked and answered. A moderator can give it a more generic title any time you'd like to suggest one.
Unread 06-03-2020, 12:58 PM   #30
Jax2000
Gotcha CX! Makes sense. Thanks!
Jax
Green board? Cement board? Kerdi board? cburrows84 Tile Forum/Advice Board 7 03-21-2014 11:44 AM
shower rebuild - need help with backer board & green board johndoe12345 Tile Forum/Advice Board 9 11-28-2011 10:50 AM
Standard Sheetrock, Green board, or Cement Board skengum@hotmail Tile Forum/Advice Board 5 09-07-2008 06:34 PM
joint btwn cement board/green board tilingisfun Tile Forum/Advice Board 8 01-11-2006 06:38 PM
green board question-a little off topic macska Tile Forum/Advice Board 5 04-24-2005 05:52 PM
