Unread 05-31-2020, 05:26 PM   #1
Dan White
Tiling over asphalt driveway
I know this is probably a pipe dream but I'm wondering if there are any advancements in Ditra type underlayment (that can handle the weight) or thinset that make it possible to lay outdoor porcelain tile over an asphalt driveway without having to remove the asphalt and prep a substrate as you would have to do with pavers. I want to upgrade from asphalt but am not crazy about pavers.
I'm pretty sure I know the answer but much of what I found on google was from years ago and I thought maybe there is something out there more recently that would make it work.
Dan White is offline   Reply With Quote
Unread 05-31-2020, 06:18 PM   #2
Asphalt is more like a thick liquid than a solid...I'm sure you've seen ruts in the stuff caused by weight and exacerbated when it's hot and the stuff softens. Plus, thinset probably won't bond to it all that well, either.
None of the membranes can handle vertical movement. Don't think it will work for you. Tile can't handle vertical movement, either.
Unread 05-31-2020, 06:25 PM   #3
Hi Dan. I don't know of anything myself. I don't think tile would hold up very well over asphalt. My dad use to say that tile is only as good as what's behind it. It's only a pretty surface.
Many years ago we tiled a couple driveways in California. They were over concrete. If the concrete cracks, so does the tile.
Unread 06-01-2020, 01:59 PM   #4
Dan White
Thanks for the no so encouraging but realistic replies!
Unread 06-01-2020, 04:42 PM   #5
If you can stand the additional height, you might get pavers on a sand bed to work over the asphalt. To get things a bit lower, you could have some of the surface ground down. That could be problematic, though, as it would have to be sloped so it could drain.
Removing thinset on asphalt driveway kenny_n Cleaning, Restoration and Sealing 4 07-15-2012 12:12 AM
Tiling over Asphalt Tile? austin_103 Professionals' Hangout 9 12-04-2009 08:12 PM
Tiling an Asphalt Deck Hereed Tile Forum/Advice Board 6 04-17-2008 09:34 PM
Tiling over Asphalt? craig_caputo Tile Forum/Advice Board 2 03-28-2006 01:32 PM
tiling a concrete driveway and walk zman Tile Forum/Advice Board 2 02-22-2005 07:16 AM
