Unread 08-02-2022, 08:45 AM   #1
AlpineVT
foam in slab
Name:  Foam in slab.jpg
Hello, Curious if anyone else has dealt with this scenario?
It's an entry 250 sq radiant in slab that has a foam boarder along exterior edge that will need to be covered. Am thinking to level foam, crack isolate with fabric, then cover with ditra. This floor also has to level out to 3/4" wood floor..
Thanks Hank in VT
Hank
AlpineVT is offline   Reply With Quote
Unread 08-02-2022, 09:15 AM   #2
Welcome back, Hank.
There's a place in your User Profile for that geographic location so it will appear in each post.
Not sure what I'm seeing in your photo. Is the black material the foam of which you speak?
What's under the foam?
Is the concrete we see under the door in plane with the concrete field?
Not at all sure why you'd want to put Ditra on top of a crack isolation membrane. What's the thinking there?
You understand that whatever you do to fill that void, you'll need to honor the joint between that and the concrete slab up through the tile installation, right?
Unread 08-02-2022, 03:07 PM   #3
AlpineVT
Thanks it's been a wile!
Yes the black material is "the foam" and concrete is in plane. The foam is a thermal break that is as deep as the footing at least 4'. (Was told it's part of the weatherization code)
I am aware of keeping a movement joint through planes but in this case they do not want to see one. Intending to land a grout joint on it so it can be color matched caulked or just repair grout in time.
I have had extremely successful results in the past using this method to cure cracks. Seems to "catch" the crack in the 1st layer of crack suppression and not carry on under the uncoupling. Or else I've just gotten lucky! Tried it 1st on a repair that I didn't set the original tile, been doing fine 10yrs+
Curious to see if anyone else has had to deal with this.
Hank
Unread 08-02-2022, 03:13 PM   #4
Again, a reason why it's important to have a geographic location in your User Profile.
...but in this case they do not want to see one. Intending to land a grout joint on it so it can be color matched caulked...
They never want to see one, Hank! Your intent is exactly what I meant by honoring the joint, but a grout joint width may or may not be sufficient. And you really want a flexible sealant in that joint, rather than just caulk.
Unread 08-02-2022, 03:35 PM   #5
The foam would not be the greatest support for tile along that edge!
How dense is it? It might work, but I'd be worried about support for the tile there.
Unread 08-03-2022, 06:12 AM   #6
AlpineVT
foam in slab
I'm in Vermont. We go from -20F winter to 90F summers.. I am worried about support as well, that's why I've come to this great site that has seen a lot of scenario's. The foam is ridged, feels about same or stiffer density as the Wedi foam core. The doors are set back from the wall and do not have a threshold to cover this small indent that exposes the insulation...and they (architect & owner) do not want thresholds but for a clean run to the doors. Might do a little digging and pour a fortified mud bed. Then crack suppression-fabric with hydro-ban, then strata-mat. Grout line on crack zone
Hank
Unread 08-03-2022, 04:19 PM   #7
AlpineVT
Heard back from Latacrete Help desk's This was the response....
"I agree with your thoughts on mitigating the thermal break area by cutting back the foam, skim with thinset like 254 Platinum. Let this set up. Treat with Hydroban and fabric is optional (but a good insurance policy) and finally cover with Strata mat, tile, grout. Sounds like a good plan."
Works for me but am still curious if I'm the only one seeing this...
Hank
Unread 08-03-2022, 06:04 PM   #8
As people become more and more interested in energy efficiency and codes change, I think you'll see more effort to provide thermal breaks for building methods.
I just got a notice from my electricity supplier...prices going up over 30% starting next month. Energy efficiency has always been a viable goal, but as it becomes more expensive, and the reality of warming, it becomes more important.
Unread 08-04-2022, 04:48 AM   #9
CaliGrown
CaliGrown's Avatar
Hank,
I don’t see any issues with your proposed plan. Especially with Laticrete’s sign-off, I’d go that route and not think twice of it. They can send over a spec sheet highlighting their intended method, should you need documentation resources.
A mud bed is always another route that can be applied in almost every case, should depth/build-out not be a prohibitive factor. Keep on trucking!!
Christopher Machado
1 (916) 990-1751
Advice for tile on basement slab - foam sandwich toddmanqa Tile Forum/Advice Board 15 06-18-2015 01:00 PM
tiling over OSB+foam subfloor on slab fusion_ta66 Tile Forum/Advice Board 17 08-25-2014 08:34 PM
Hydroban over foam pan Jim Cordes Professionals' Hangout 8 06-07-2014 08:01 AM
foam board bentoveragain Professionals' Hangout 7 10-06-2009 07:38 AM
