Unread 06-03-2022, 07:41 AM   #1
Lou_MA
Removing freshly set tiles over ditra
Been setting over ditra for years and happened to think of this the other day.
In the rare case I’m installing ditra and setting tile same day, if I need to remove a freshly set tile, I’ll slide it an inch or two before lifting up. Don’t want to break bond between ditra and substrate.
Much more common is me installing ditra one day, then setting the next day. At which point it’s just my regular MO…stick my margin trowel under the tile edge and lever the sucker straight up.
Other people doing the same as me? Or you all doing the slide / lift over ditra all the time?
Lou
Unread 06-03-2022, 05:50 PM   #2
Hi Lou. Even though the thinset may be set enough, I probably wouldn't lift straight up until the thinset dries a few days, just to be safe.
Unread 06-03-2022, 09:50 PM   #3
I slide the tile several inches to the open side while lifting gently.
Unread 06-04-2022, 07:18 AM   #4
Tiger Mountain Tile Inc
I never install over fresh Ditra. It's just a rule I have for myself.
James Upton
Unread 06-09-2022, 04:00 PM   #5
give the tile an tap with the hammer and smash into pieces, then there's less area pulling up when you lift the broken pieces.
^^Check out our Blog^^
Unread 06-09-2022, 11:59 PM   #6
CaliGrown
CaliGrown's Avatar
I concur with Brian
Christopher Machado
1 (916) 990-1751
Removing ditra beckygriff Tile Forum/Advice Board 3 10-22-2015 09:53 PM
How to stain or darken freshly stripped saltillo tiles - less "pink" grafcus Cleaning, Restoration and Sealing 7 09-25-2015 01:04 PM
Removing Ditra Redrobster78 Tile Forum/Advice Board 3 05-13-2012 06:33 PM
basic ? - OK to install freshly cut tiles? james36 Tile Forum/Advice Board 8 10-11-2007 11:32 AM
Enhancing a freshly sealed new slate counter Soonerob7 Cleaning, Restoration and Sealing 1 07-10-2007 08:23 PM
