Unread 08-05-2022, 09:56 PM   #1
thomps8383
Water Proof between Cement board and Kerdi Niche
I have a Kerdi Niche with the remaining walls in the shower surround cement board. What would be the proper way to seal and water proof the seam between the cement board and Kerdi Niche?
I planned on putting TEC Hydraflex waterproofing on the cement board, can this also go on the Kerdi Niche?
Thanks for any help in advance
Troy
thomps8383 is offline   Reply With Quote
Unread 08-06-2022, 01:28 AM   #2
CaliGrown
CaliGrown's Avatar
After you tape and thinset the seams in the Durock, do the same at the kerdi board to cement board junctions. Once cured and dry run the Tec Waterproofing business as usual
Christopher Machado
1 (916) 990-1751
Unread 08-06-2022, 07:13 AM   #3
thomps8383
Can the waterproofing go on the Kerdi Niche also? Or just waterproof the seam between the cement board and niche and leave the remaining portion of the niche without the waterproofing?
Troy
Unread 08-06-2022, 07:34 AM   #4
You can overlap the seam with the waterproofing. Once you thinset the mesh tape on just cover the thinset with the waterproofing liquid.
James Upton
Unread 08-06-2022, 11:49 AM   #5
thomps8383
Thanks for the help.
Troy
Unread 08-06-2022, 03:05 PM   #6
thomps8383
So after the thin set dries water proof everything but the inside of the niche?
Troy
Unread 08-06-2022, 05:45 PM   #7
CaliGrown
CaliGrown's Avatar
Yes sir, that’s the ticket
Christopher Machado
1 (916) 990-1751
Unread 08-06-2022, 06:02 PM   #8
is that drywall mud or white thinset? I ask because you have grey around the niche and white every where else
Unread 08-07-2022, 07:07 AM   #9
thomps8383
Shawn, No everything on the cement board and niche is thinset. White is just what they had for a modified thinset that's on the cement board. The gray thinset is a unmodified according to Kerdi spec's.
I'm going to use the unmodified thinset for the niche to set the tile to comply with kerdi instructions and modified on everything else to set the tiles.
Troy
Unread 08-07-2022, 08:17 AM   #10
Troy, since your combination of materials and installations strays from Schulters recommendations for their products, thus precluding any possible warranty claim you might bring, you honestly have nothing to gain from using an unmodified thinset mortar.
The modified you have used on everything else will be absolutely fine for the niche.
Kerdi Board with Kerdi niche with prefab fiberglass shower pan Jeff753 Tile Forum/Advice Board 12 11-10-2021 08:23 AM
Kerdi niche to water proof hardi backer transition? Ceramictilenube Tile Forum/Advice Board 9 11-22-2020 10:56 PM
Kerdi Niche Cement Board? juttmk Tile Forum/Advice Board 25 04-06-2018 07:37 AM
Kerdi On Cement Board No Water KenNJ Tile Forum/Advice Board 2 06-15-2017 01:13 PM
water proof backer board estokes-tucson Tile Forum/Advice Board 1 06-18-2003 12:44 PM
