Unread 12-11-2009, 01:28 PM   #1
fourml8r
fourml8r's Avatar
Subfloor and wall framing question
I noticed during demo work that my builder installed the first subfloor layer, then framed the shower walls and set the top subfloor layer (Trimming it around the framed walls). I am ripping these walls out to install new ones (In a different location). I have removed the top subfloor layer and will be putting down some thicker plywood, so my floor is "Wide open" until the new walls are framed. I was thinking it would be easier and faster to lay all the top subfloor (5/8" plywood) and then frame the shower walls on top of it. I would imagine the plywood floor has more "strength" if it stays intact.
This will be a Kerdi shower with a Kerdi pan, Any input on this?
harris
fourml8r is offline   Reply With Quote
Unread 12-11-2009, 02:00 PM   #2
Tim K
the only problem with doing it that way, is that you can't use a standard stud. You'd have to shorten each stud the thickness of the plywood. If it's a short wall wouldn't be a big problem, but if you have lots of walls.......
Tim K is offline   Reply With Quote
Unread 12-11-2009, 05:28 PM   #3
silvercitytile
silvercitytile's Avatar
other than what tim said. i think u'll be fine.
the studs are gonna be what ever the hieght of the room is minus the top and bottom plate, no matter what.
Castillo Construction
First post - a framing/subfloor question of course! live4ever Tile Forum/Advice Board 2 02-12-2009 06:29 AM
Just starting - Wall framing question tilemaniac Tile Forum/Advice Board 4 07-20-2008 09:29 PM
Framing Question Jack 1 Tile Forum/Advice Board 8 08-07-2006 10:34 AM
framing question nrcurcio Tile Forum/Advice Board 4 03-16-2006 01:57 PM
subfloor over post and beam framing? levind Tile Forum/Advice Board 3 05-08-2005 04:18 PM
