Unread 01-17-2016, 10:54 AM   #1
wwhitney
Wall framing
Originally Posted by cx
The stud wall does not qualify as a support wall without adequate sheathing on at least one side or proper blocking between studs.
I wasn't aware that sheathing would be required, although I agree it is a good practice. Do you have a building code reference? I would think that if the wall is only designed for gravity loads, and isn't part of the lateral force resisting system, that it wouldn't need sheathing.
Cheers, Wayne
Wayne
Unread 01-17-2016, 11:01 AM   #2
Because the unsheathed studs can (and will) bend in every direction independently. The sheathing and blocking greatly reduces the chances of that happening.
R602.4 Interior load-bearing walls. Interior load-bearing walls shall be constructed, framed and fireblocked as specified for exterior walls.
Last edited by Houston Remodeler; 01-17-2016 at 11:06 AM. Reason: That's with only one cup of coffee
Unread 01-17-2016, 11:03 AM   #3
Don't have a code citation for you, Wayne, but it's not really lateral load in question here. It's the flexing of the individual studs when vertical load is applied that can be a problem in allowing the floor joists to deflect where no deflection at all is desired for the support. A 2x6 wall will do better than a 2x4 wall, of course, but both still require sheathing or blocking.
Unread 01-17-2016, 11:53 AM   #4
wwhitney
Thanks Paul and CX for the explanation, and thanks Paul for the code cite:
I did see that part of the IRC, but I didn't see where unsheathed exterior walls require mid height blocking. I dimly recall a requirement that applies if the studs are over 10' or something like that.
But the upshot for the OP is that a tile installation will be improved by installing either sheathing or mid-height blocking on that supporting wall. At least under the joists that are supporting the area to be tiled.
Cheers,
Wayne
Wayne
Framing issue- rot behind tub on outside wall Delta_V Tile Forum/Advice Board 6 12-18-2013 09:44 AM
Subfloor and wall framing for tile shower/bathroom pulrich Tile Forum/Advice Board 6 06-08-2011 02:09 PM
Subfloor and wall framing question fourml8r Tile Forum/Advice Board 2 12-11-2009 05:28 PM
Just starting - Wall framing question tilemaniac Tile Forum/Advice Board 4 07-20-2008 09:29 PM
Framing Simple Professionals' Hangout 18 01-13-2005 08:43 AM
