Unread 01-14-2012, 10:30 PM   #1
DieselDennis
Dennis
A Clean Cut on Tile
I have a little project coming up. Master tub is set in the corner of the bathroom and I want a tile surround around it.
The tile I have to work with is 3" x 13" bullnose trim pieces. However, I need pieces that are only 2" wide. This leaves me to have to rip the 3"x13" pieces down to 2"x13". Keep in mind these tiles will be around the top of the tub, a very visible location.
My question is what method will leave me with the cleanest cut? I have a bridge tile saw, but I wonder if I should invest in one of those score & snap tile cutters instead. The tile (ceramic) is brown on the surface, but a terra cotta underneath. This means all the little chips show. Grout is also a similar color brown.
So how would you make the cuts?
DieselDennis is offline   Reply With Quote
Unread 01-14-2012, 10:38 PM   #2
muskymike
muskymike's Avatar
Hi Dennis, I would cut them on the saw.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Unread 01-15-2012, 09:11 AM   #3
vrusso123
N. E. Ohio tile-setter
if that bridge saw plunge cuts i would score across the glaze first then cut body. works well for me, and the cuts are straighter.
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
Can anyone help me clean this tile? Presidential Cleaning Cleaning, Restoration and Sealing 1 11-13-2008 05:43 PM
How to Clean Old Tile Doone Tile Forum/Advice Board 5 03-02-2007 10:19 AM
What do I clean my tile with? bigcaat Cleaning, Restoration and Sealing 1 11-17-2006 03:45 PM
How do you clean your tile saw? Dan Clark Tile Forum/Advice Board 16 10-30-2006 08:17 PM
clean new tile help... milwaukeeiron Cleaning, Restoration and Sealing 5 05-13-2005 04:51 PM
