Unread 03-09-2008, 11:48 AM   #1
SusanT
Smoothing porcelain tile edge
We just put in a porcelain tile countertop in kitchen. We used Crossville crosscolors. I looks great, but I would like to smooth the edges a little so they are not so sharp. Is there anyway to do this?
SusanT is offline   Reply With Quote
Unread 03-09-2008, 11:55 AM   #2
Porcelain is the hardest tile made, you would need very expensive machines to do buffing. you can try to use a Rubbing Stone to take the sharp edge off the cut.
or if you have a wet saw, run the cut across the Side of the blade to take off the edge.
^^Check out our Blog^^
Unread 03-09-2008, 12:05 PM   #3
SusanT
Thanks. I see the local Big Box Store sells a two sided rubbing stone one side #60 grit the other #80. Will this do?
Unread 03-09-2008, 12:21 PM   #4
it only comes in one grit style.
Unread 03-09-2008, 01:34 PM   #5
Rd Tile
Tile Man
Rd Tile's Avatar
Nope, 80 one side, 60 the other, one stone.
Richie.
Unread 03-09-2008, 03:57 PM   #6
wow, I must but the cheap type...or I never knew that.
Unread 03-09-2008, 04:07 PM   #7
Lazarus
Lazarus's Avatar
Yep, mine has two grits. Try the rough one first and then finish with the smooth one.
Laz...
“Always listen to experts. They'll tell you what can't be done, and why. Then do it.”
Unread 03-09-2008, 04:26 PM   #8
Rd Tile
Tile Man
Rd Tile's Avatar
http://www.homedepot.com/webapp/wcs/...key=THDSiteMap
Richie.
Unread 03-09-2008, 04:40 PM   #9
I thought the rough side was for your hand so it wouldn't slip out....lol
just kidding.
