Unread 06-24-2022, 09:02 AM   #1
mrkski77
screws on top of shower curb and below curb
Here's some photos from my ongoing shower install. The contractor (with 20 years of shower building experience) insists no waterproofing membrane is necessary on the durock shower walls even though we asked him to install redgard. There is no plastic between the durock and studs either. He started installing tile and now I see screws going into the durock below the curb level and also on top of the curb which seems like a no-no from reading these forums.
We are asking him to re-do the walls and use a waterproof membrane but before I also complain about these screws, is there any possible way this is ok and he's going to waterproof these holes later? Thank you.
Mark
mrkski77 is offline   Reply With Quote
Unread 06-24-2022, 09:26 AM   #2
Dave Gobis
da Man!
Dave Gobis's Avatar
It is not OK and there is no effective way to tie in waterproofing now. Based on his trowel skills I highly doubt the 20 years' experience. It will be much cheaper and easier to deal with now than continuing and hoping for the best. Your correct on the plastic or paper on the studs. Durock is unaffected by water but not waterproofing.
Unread 06-24-2022, 03:20 PM   #3
The moral to this story is that way too many people do things wrong for way too long! To their defense, what they do wrong may take a number of years before it exhibits problems, and most only provide a 1-year warranty, so may not know about the issues they cause.
People tend to get the idea that all tiled showers fail after time, and that's because a large proportion of them are not built to industry standards.
A shower should last without issues until you decide to remodel, not because it has performance issues.
Unread 06-24-2022, 05:25 PM   #4
What Jim and Dave said, give him the boot.
Unread 06-24-2022, 09:25 PM   #5
I agree with them all. I’m not piling on for no reason…I just don’t want you to be convinced with some seemingly logical reason your contractor gives you and you give it a chance. This is a re-do. Not a fix. You simply want this shower built using an industry-recognized and published standard.
Unread 06-24-2022, 10:41 PM   #6
You could ask him which TCNA industry shower build method he's using. He probably won't know what you're talking about, but he should. There's more than one way to build a reliable, long-lasting shower, and each method has its advantages and disadvantages, but they all work IF you follow the instructions and have good workmanship. What he's done so far does not meet any of the industry guidelines, and would lose in court if it were to get that far.
Unread 06-26-2022, 01:21 AM   #7
I feel compelled to say one positive thing.
At least he put mesh tape on the seams.
That's about all.
Unread 06-27-2022, 11:47 AM   #8
mrkski77
Thank you everyone! We will do a do-over. Better now than in later. Thanks again.
Mark
Shower door install - instruction require screws into curb jetpeach Tile Forum/Advice Board 8 10-22-2017 07:22 PM
Shower pan Liner curb with screws LadyReddy Tile Forum/Advice Board 16 10-19-2017 08:05 PM
screws thru cbu on curb, then sealer? Michael Kehoe Tile Forum/Advice Board 2 07-15-2015 07:57 AM
Tiling a varying-height shower curb; Penny tile OK on top of curb? smcquaid Tile Forum/Advice Board 6 01-07-2012 09:02 PM
Building Shower Curb Using Durock And Then Sealing Screws With Contact Cement 6mopregnant Tile Forum/Advice Board 10 11-13-2007 10:06 PM
