Unread 07-30-2017, 10:49 AM   #1
Porter3445
Re-do accent tiles
The contractor left too big a space for the accent tile and now there is too much grout top/bottom and it's crooked. Question: can the accent tile be replaced or do you have to rip out the other tile as well? Accent tile is on the floor and in the shower.
Kay
Porter3445 is offline   Reply With Quote
Unread 07-30-2017, 10:50 AM   #2
jaslan
Yes tear up the accent tile
Sent from my SM-G930W8 using Tapatalk
Jason
jaslan is offline   Reply With Quote
Unread 07-30-2017, 10:51 AM   #3
jaslan
Did he precut the border/ accent tile? He can re cut it wider and install spacers on the top and bottom....
It would be cheaper them tear up the walls
Jason
Unread 07-30-2017, 10:52 AM   #4
jaslan
Looks horrible I agree...im a tile guy I wouldn't accept this type of work
Jason
Unread 07-30-2017, 11:01 AM   #5
I'm with Jaslan, have him replace just the top and bottom border. It's a shame he left it like this because it's a nice looking border from a distance. Cross your fingers that the substrate isn't damaged from pulling the tiles.
Unread 07-30-2017, 11:04 AM   #6
Porter3445
Re-do accent tiles
This was a pre-cut border so that's the problem. Not sure if he can "add" a black ledge to fill in gap?
Kay
Unread 07-30-2017, 11:06 AM   #7
He would have to find the black material in a larger size and cut them to fit.
Unread 07-30-2017, 02:50 PM   #8
Lazarus
Lazarus's Avatar
I agree. He needs to remove the black and re-cut them from new tile to a larger size...
Laz...
“Always listen to experts. They'll tell you what can't be done, and why. Then do it.”
Unread 07-30-2017, 05:07 PM   #9
evan1968
Not So Senior Contributor
evan1968's Avatar
Missed by that much.
That's awful. Hope he doesn't disturb the waterproofing, which every properly installed shower should have,when he removes and replaces the tile.
Ask how he will not compromise the waterproofing with the repair, see what he says.
Craig
Commercial Tile Installations
KEEP CALM and TILE ON
Unread 07-31-2017, 10:46 AM   #10
Porter3445
Re-Do Accent Tile
Thank you for the response! The contractor doesn't see a problem so I may have to find someone else to fix this but lessons learned.
Kay
Unread 07-31-2017, 04:50 PM   #11
mark999
Kay
Did you pay in full for the job? If no that is good. If yes that is not good.
Mark
Unread 07-31-2017, 04:56 PM   #12
eurob
Not...Sure
Now , you have place for 3 full dots
Roberto
Unread 08-01-2017, 10:48 AM   #13
Porter3445
Re-Do Accent Tiles
We didn't pay full price but close enough. I think we are going to have to leave it as is. He moved out of state, which I believe was why he rushed the job. It would cost quite a bit to have someone repair the tile and I would be afraid to ruin the back board. The contractor did work for us previously and all was well. I think he just had too much going on in his life at the time of this job.
Kay
Unread 08-01-2017, 04:30 PM   #14
tatumjonj
I don't think it was a case of too much going on his life versus he just measured wrong.
Jon
Epoxy grout used for accent glass and stone tiles Bob Turek Tile Forum/Advice Board 2 11-22-2013 05:20 AM
Anybody channeled Wedi for thicker accent tiles? Topspin Professionals' Hangout 16 02-20-2013 09:04 PM
Adding Thickness to Accent Tiles papazian Tile Forum/Advice Board 6 01-24-2008 07:44 PM
Cutting granite tiles for an accent strip wendyG Tile Forum/Advice Board 1 06-03-2006 10:27 AM
Floor Accent Tiles jlbos83 Tile Forum/Advice Board 4 05-18-2002 10:19 PM
